Rear work light on a WD
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Rear work light on a WD
    Posted: 27 Sep 2020 at 5:36pm
I realize that most model WD's came from the factory with that red rear "bullet" tail light.  However, I have seen some with a rear work light instead.  Not sure if this was an option or what.  However, I purchased what appears to be one and would like to install it.  I think I've seen a picture of one under the seat.  Anyone have any thoughts on this topic?  Many thanks in advance!
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 6:01pm
The two WD'S we had back in the 50' & 60's when I was growing up both had rear work lights. The one on the tractor purchased new in 1949 had been added by my uncle by fabricating a bracket and mounting it to the seat mounting bolt. The other WD was purchased used and the previous owner had mounted a light in place of the red bullet light on the left hand fender. Neither was what I would term a "factory" light although they may have been available through the dealers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 7:29pm
Mine has the red bullet light but I added a flood off of another WD that was being parted out. Same one I got the foot throttle off of which I really enjoy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 7:33pm
It wires the the same circuit as the red light but has a on/off switch. L bracket mounted on a transmission bolt under the seat.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 8:44pm
The one I had, had a switch on the light.  One way was a red tail light and the other way was the work light. Center was off.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 8:33am
WD (S/N 5109) 1949 had both  the rear red bullet light on the fender and a rear work light mounted under the seat.  As far as I know, both are factory original, but dad always mentioned that the chrome bezel around the red taillight was the only one he had seen.  The rear work light does not have a separate switch; it comes on with the rest of the lighting.               R. Musgrave
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 12:17pm
This is my 1953 WD-45.  Rear work light is mounted to a bracket that is fastened to the seat bracket.  I have no idea when it was added.  I'm guessing it was a dealer installed option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 5:11pm
Brian F:  This picture is so helpful!  Especially showing your tractor has the "bullet" light as well as the rear work light.  The original rear work light I purchased has a bracket attached to it.  So it sounds like I just need to attach it to the seat.  I don't have a bullet light right now, so I can use that wire to connect to the rear work light.  Thanks for all the responses.
