Unofficial Allis Homepage
Rear tractor tires
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Topic: Rear tractor tires
    Posted: 21 Jan 2020 at 1:44pm
What does everyone think of BKT tires for my D17 ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 1:57pm
I've had a set of 14.9 x 28's  6 ply on my WD45 for 6 years now and am happy with how they seem to wear and traction. But, it isn't a full time use tractor. I do about 300 miles a Summer of tractor riding and a little moldboard plowing for show. They are physically big for their size. I think you'll like them. I would buy another set in a heartbeat.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 2:01pm
My dad has BKT's on his IH 340 for 4 years and uses it to pull logs out of the woods, bale hay and rake hay. No problems so far.
A&W TRACTOR REPAIR
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 3:09pm
Like everything else in life you get what you pay for. No cheap tires for me. I’ve tried it and regretted it both times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 3:27pm
Dave,
 I had a set on one of the tractors. They seemed OK. Good luck with your new tires!
D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Ford Jubilee, IH TD6 Many IH Cub Cadets
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 4:52pm
I almost went BKT but the Firestone SAT II 23 degree came in about 50.00 more per tire so I went with Firestone's.   {18.4 x 38's}
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 5:34pm
Got a set on a 190, 18.4-34,s , seem to be good but one seems about and 1.5 inches taller than the other , both have the same air pressure too
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 9:11pm
I have a set of BKTs on one of my WD45s they have been on for 10 years mine are 8 ply and are a little stiff. They still look like new there is no wear and no weather checking my tractors are parked inside all the time so they don't weather. They have good traction I put on new rims with new Goodyear tubes when I installed and haven't Touched them since. They are a couple inches taller than the good years or firestones they are R1 tread pattern.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 10:07am
I have a set of BKT's on the rear of my B and WC. I like them.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 10:49am
I have a set on my combine.  I'd have to look for sure, but I'm going to say for about 8 years now?  Doesn't see tons of acres/ hours, but sees some abuse from corn stalks for sure.  Work fine for traction and mud, and no gouges or premature wear so far.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 11:21am
They are ok on a chore tractor. Anything on a full use tractor gets Firestone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 5:28pm
I am putting on Titans not much more.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 5:34pm
Dr Allis I have just the opposite experience.  Have 190xt with BFG 34" tires parked next to 220 with BKT 38" tires and they are the same height.   Just my experience.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 7:47am
Whatever you do don't buy a chinese made tire. I've seen what they look like in less than 10 years. Firestone for me.
Wink
I live in Minnesota but am a Russian Bot
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 1:14pm
I need rims now 15x28 put this on Classifted page too. Not having to much luck hate to spend that much on that tractor but guess I will have to.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 3:48pm
I went with Goodyear 14.9 x 28” on my 45 a few years ago. They are not as wide as the 13.6’s that I pulled off. They sit square with a 12” rim. Height and traction are fine.
