Pulling again. weights...
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=55189
Printed Date: 10 Sep 2025 at 5:03am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Pulling again. weights...
Posted By: AC WD45
Subject: Pulling again. weights...
Date Posted: 13 Aug 2012 at 2:02pm
I started pulling again this past week (first time in 2 years) and my WD45 is almost exactly 500 lbs likeg. I am pulling in the 4500lb class. I am thinking about making a weight bracket and bolting it to the rock plate to hang some suitcase weights from. does anybod have ny pictures of their set up? this is on a WD45. I do not want to remove anything from the tractor, so I cant have anything that will interfere with the 3pt hitch. I am just a weekend warior and need to be able to use the tractor during the week. also, what can I expect to pay for weights? say any brand.
------------- German Shepherd dad 1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193
Posted By: ALinIL
Date Posted: 13 Aug 2012 at 5:09pm
I too pull occasionally with a 45. It is stock and weighs 4000 with me(200#) and 2 - 130# weights. It is a little lite on the front. Suggest hanging 2 weights from the frame(mid) and another set on wheels. I run 18-20in hitch height.
Posted By: HagerAC
Date Posted: 13 Aug 2012 at 10:52pm
I've got a weight bracket on each side on the front, and I also made a weight bracket to fit into the snap coupler latches on the back.
------------- 30+ A-Cs ranging from a 1928 20-35, to a 1984 8070FWA, Gleaner R52
Posted By: rob young
Date Posted: 14 Aug 2012 at 8:27am
weight prices in my area are usually a $1 a pound. give or take a little. i also made brackets on each side of the frame mid mount where the frame bolts to bell housing mounts. also made one for front using the bolt holes in the frame, but some clubs dont allow weight past front of tractor so beware of that.
