Print Page | Close Window
Cross mfg 3 point hitch
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=55122
Printed Date: 26 Jul 2025 at 6:15am
Topic: Cross mfg 3 point hitch
Posted By: ricksam
Subject: Cross mfg 3 point hitch
Date Posted: 12 Aug 2012 at 7:49am
Has anyone put this 3 point on their WD/WD45?  If you have, how did you attach the sway chains???  It says "use the existing drawbar support bracketry", but I cannot see how that will work as it will severely limit the range of motion.  Solution?
Posted By: Lance/SC
Date Posted: 12 Aug 2012 at 9:08am
My CA has a drawbar similar to the WD and when it is removed and the 3 point popped into the snap coupler the tubing that the chain is hooked to goes up and a piece of 3/4 rod pins it to the drawbar support brackets.  Mine had a bolt through it that was bent from the action of the traction booster system and it wouldn't come off when I took the nut off it.  It had to be cut off in pieces.  I have a piece of 3/4 threadded rod I am going to use when I need it but that will only be for light work.
Posted By: Dakota Dave
Date Posted: 12 Aug 2012 at 10:02am
I have one on My WD45, the chains go from the mid point of the arm to the drawbar supports. the Tube with the short chains attached is supposed to pin into it. Mine did not work the chains were so short.  I ran longer chains and crossed them across to the other side drawbar support and attached with a clevis. Adjust them so they are tight when the implement is all the way on the ground. when the implement is lifted it will sway some but the lifting arms will keep it mostly straight behind the tractor. It really depends on what you plan on useing on it. Draft implements will center themselfs behind the tractor if properly adjusted. A mower or snowblower will need the chains tight when lowered all the way down to stay in place. PTO equipment will require removal of the cross tube or you'll brake the PTO.
Posted By: Pat the Plumber CIL
Date Posted: 12 Aug 2012 at 11:16am
Like Dave said chains are probably too short, I added chain links and crossed like Dave. Take the center bar out if you are going to mow. You will not need it. I took a length of 5/8" all thread and washers as spacers and made a way to connect tube to drawbar supports. Works great for mowing, Would put cross brace back in for snow plowing or field work.
Posted By: ricksam
Date Posted: 12 Aug 2012 at 6:08pm
Those chains are too short so sounds like lengthening and crossing them is a good idea.  Great help fellas...thanks bunch.
