Tank liner went bad!!!
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=51729
Printed Date: 27 Aug 2025 at 6:16am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Tank liner went bad!!!
Posted By: JW in MO
Subject: Tank liner went bad!!!
Date Posted: 07 Jun 2012 at 2:31pm
Getting ready for upcoming shows I cranked up the A and headed out to the yard for a quick shower. Made it to the middle of the shed door when it died and you only crank a few times before breathlessly checking for symptoms. Opened up gas cap and the tank liner looked like cob webs in a haunted house. I only assume it was the Kreem liner or similar product and it was white and hard as a rock before. The liner was installed 13 years ago and was fine until recently. It has never had ethenol in the tank, I've only used 92 octane premium gasoline. The only thing I've done different is last fall I put Sta-bil in the fuel, and it was fine then. Is Sta-bil that agressive, the Kreem type liner prone to breaking down, or a combination of high octane and Sta-bil, or just not my day?
------------- Maximum use of available resources!
Posted By: injpumpEd
Date Posted: 07 Jun 2012 at 2:44pm
I had Kreem lift on the aluminum tanks of all 3 of my JR Dragsters. But they run on methanol. Was ok for a year or two.
------------- 210 "too hot to farm" puller, part of the "insane pumpkin posse". Owner of Guenther Heritage Diesel, specializing in fuel injection systems on heritage era tractors. stock rebuilds to all out pullers!
Posted By: TREVMAN
Date Posted: 07 Jun 2012 at 6:42pm
Ive only used tank liner twice, the first and the last time. I have no faith in the stuff, I think it causes more problems than potentially it could fix, just my opinion, Trev.
Posted By: Stan R
Date Posted: 07 Jun 2012 at 8:47pm
I know there has been a lot of successes with gas tank liners, but being a Chemical Engineer and knowing how aggressive organics can be to plastics, epoxies, etc., I'm a believer of good old fashioned steel to contain gasoline. For instance, at one of our manufacturing sites, we had a 10,000 gallon fiberglass tank that was specified to contain propylene glycol (and warranted by the manufacturer), however, within a year or so, the tank leached out epoxy components into the glycol which was used in pharmaceutical manufacturing. After a lot of analysis, it turned out that one minor additive at a very small concentration within the glycol caused this failure.
