Print Page | Close Window
WD45 Shifting Troubles
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=51080
Printed Date: 24 Aug 2025 at 2:20am
Topic: WD45 Shifting Troubles
Posted By: OrangerO
Subject: WD45 Shifting Troubles
Date Posted: 24 May 2012 at 8:46pm
Took my WD45 to the Buckeye Farm Antiques show in Wapakoneta, OH this evening. Got it in line then decided to give the tractor next to me and myself some extra room, but when I tried to shift it out of first gear the shifter would not pull back to netral.  So I pulled harder- not good, now the shifter moves side to side like it's in neutral but farther forward like it's in the 1-3 area of the pattern and the trans is stuck in first.  I think I'll be OK this weekend and can get it loaded and home on Sunday if I'm careful, but what then?  Any of you have suggestions, advice, or experience in fixing this problem and be willing to share your wisdome.  Any help would be most welcome.  Thanks  TR
Posted By: MACK
Date Posted: 24 May 2012 at 9:31pm
Lift rubber boot and remove snapring holding gear shift in, be careful not to loose the side pins. Look in hole and with long screw driver, aline all 3 slots then drop gear shift back in. About time to rebuild cover.   MACK
Posted By: OrangerO
Date Posted: 25 May 2012 at 4:02pm
Thanks for the advice.  TR
Posted By: Dakota Dave
Date Posted: 25 May 2012 at 9:40pm
After you get it home pull the shifter back out and weld it so its 1/2" round and 3/8" wide at the end. put it back in and you should be good. If that doesn't fix it than you'll need to remove the cover and reweld or replace the shifter rails.
