Power Director question.........
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=42512
Printed Date: 30 Aug 2025 at 12:31am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Power Director question.........
Posted By: bincitybandit
Subject: Power Director question.........
Date Posted: 22 Dec 2011 at 8:17am
Question about the power director on a D17 & D19.............
On both tractors, the PD works find going back and forth between low and high. But when you slip it into neutral, the tractors don't stop, they keep moving forward. They seeming lose some forward momentum, but they don't completely stop. When I hold the brake, the tractor continues to fight itself. They are supposed to be able to come to a stop correct? Something wrong with both of them? Or just me?
------------- ALLIS: B, WC, G, G, D10, D12, D14, D14(NF), D15, D17, D17(NF), D19, D21, D21 MINNEAPOLIS MOLINE: U, U, U(NF), GB JOHN DEERE: L FORD: 871 Select-O-Speed CASE: 600 Combine
Posted By: John (C-IL)
Date Posted: 22 Dec 2011 at 8:49am
The adjustment could be a little tight or you could have warped discs. There is a certain amount of "drag" in them so it really depends how severe the problem is. Does it still do it after the oil has warmed up?
Posted By: Stan IL&TN
Date Posted: 22 Dec 2011 at 9:33am
When my oil is cold it will creap but when warm it will come to a stop with the PD in neutral.
------------- 1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Date Posted: 22 Dec 2011 at 9:42am
I guess I've only tried them with oil pretty cool, driving from shop to shop
Posted By: jaybmiller
Date Posted: 22 Dec 2011 at 9:54am
Both my D-14s 'creep'...seems to be common, normal. The PD consists of 2 disc packs and can be 'challenging' to adjust to factory specs.It involves a complete teardown, something most of us aren't about to do.....
------------- 3 D-14s,A-C forklift, B-112 Kubota BX23S lil' TOOT( The Other Orange Tractor)
Posted By: CTuckerNWIL
Date Posted: 22 Dec 2011 at 9:57am
It could be the fluid is a little thick also. New 20wt Hytran fluid with a little flush of the system might be a good thing.
------------- http://www.ae-ta.com" rel="nofollow - http://www.ae-ta.com Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
Posted By: DonDittmar
Date Posted: 22 Dec 2011 at 11:10am
They will creep when in nuetral until warm.....some even creep a little when warm.....its the drag of the oil between the plates. If it is warm and you cannot stop it with the brakes, or the brakes do stop it but it loads the motor, then the clutch is not adjusted correctly
Non detergent 20W is the specified oil. That can be a little tough to find so I use AW32 and some use universal tractor hydrualic fluid, which all should be acceptable
------------- Experience is a fancy name for past mistakes. "Great moments are born from great opportunity"
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start
Posted By: DSeries4
Date Posted: 22 Dec 2011 at 5:23pm
It can be reduced if adjusted when warm. This is done by adjusting the neutral location of the stick. Loosen 2 nuts on the access cover in front of the handle, then you can move the handle to where the tractor does not creep as much. Done it several times.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '63 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Posted By: Pat the Plumber CIL
Date Posted: 22 Dec 2011 at 11:18pm
On our dairy farm tractors were used daily and none (3 D-17s and one D-19) creeped at all when in nuetral. Every D series that I have test drove since then has creeped when in nuetral. An older man told me at an auction once if you took those tractors out and plowed all day with them it would probably cure it if nothing major was wrong.
------------- You only need to know 3 things to be a plumber;Crap rolls down hill,Hot is on the left and Don't bite your fingernails
