Print Page | Close Window
HP and Torque curves of 11000 MK II
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=42247
Printed Date: 29 Aug 2025 at 11:29pm
Topic: HP and Torque curves of 11000 MK II
Posted By: Orange Blood
Subject: HP and Torque curves of 11000 MK II
Date Posted: 16 Dec 2011 at 8:16pm
Does nayone here have any sales literature, or information on what the 11000 MK II, industrial power unit had for stock HP and torque curves?
Thanks,
Anthony
Still in use:
Posted By: Calvin Schmidt
Date Posted: 16 Dec 2011 at 10:13pm
The literature does not have a curve chart but lists 220 hp @ 2200 rpm and 190 hp @ 2000 rpm.  No torque ratings. Weighs 2300 lbs. Brochure on newer 685 has the same info.
Date Posted: 16 Dec 2011 at 10:17pm
Just found a spec sheet that lists peak torque 586 lb/ft. @ 1400 rpm.
Date Posted: 16 Dec 2011 at 10:24pm
Looked at an irrigation engine brochure (June 1966) and it lists this engine with 240 hp @ 2200 rpm and 645 lb/ft. torque @ 1600 rpm
Date Posted: 17 Dec 2011 at 12:25am
Thanks Calvin,  That is exactly what I wanted to hear.  So with only mild pump tweaks I can get in the 250HP range, and probably another 50 or so lbs. of torque, whigh should be well within the RTOO9513 tranny I plan to put in this thing.
Thanks again,
Anthony
Still in use:
