D-17D opinions
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=42125
Printed Date: 29 Aug 2025 at 10:10pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: D-17D opinions
Posted By: Denis in MI
Subject: D-17D opinions
Date Posted: 14 Dec 2011 at 3:49pm
So I have been getting behind on my projects, like many of us seem to do. I bought this D-17 Diesel a year or two ago and have had time to do nothing to it. The engine is seized and I have not investigated to see why. I put some oil in all the cylinders right after it came home hoping it would start working it loose. I never really tried to free it up I just left it as I have other projects to work on. So hear is my dilema, I really wanted to restore this tractor and use it, but I think a more modern machine would be better. So I am thinking maybe it needs a new home. My second thought was maybe I could pull the engine out and sell it and then repower it with a ford 302 I have laying around. The tractor is pretty straight and mostly complete but I guess I wanted to know what you guys think. Thanks in advance for any opinions, Denis
------------- 1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Posted By: HagerAC
Date Posted: 14 Dec 2011 at 3:53pm
Well they are an awesome tractor when in working order. One of my all time favorite tractors by far with such a smooth running diesel. On the otherhand it would most likely cost a fair amount to get it going again depending on engine condition. May be best to determine engine conditions and go from there depending on what you are willing to spend. Good luck. Most of it looks to be pretty straight.
------------- 30+ A-Cs ranging from a 1928 20-35, to a 1984 8070FWA, Gleaner R52
In case it makes a difference in your opinion, the left rear is about 70% tread and that rim is perfect, the right rear how ever has a pretty bad tire and the rim is getting rusty it also has the grille and left fender. It had a 3 point but I removed that and put it on one of my WD45s. It is fairly complete and has all the tin hood badges. Thanks, Denis
Posted By: ACscott
Date Posted: 14 Dec 2011 at 3:58pm
im rebuilding my D19 diesel right now, thought everything would be a simple fix but it wasnt over $5500 later i will have a nice tractor that still needs paint. Im not complaining one bit about it as I know whats in it now.
Posted By: Chris/CT
Date Posted: 14 Dec 2011 at 4:11pm
You have to be able to finance the "project" with all your heart, if it AC it's a no brainer. Look at some of the dedicated AC Forum folks who have done there machines over, they stand back and feel great. I wished I was able to finance some past projects to the end, times just didn't allow it. ACscott, thanks for your dedication to the cause, keeping the Orange Machines doing what there suppose to do.
Posted By: podunkpuller
Date Posted: 14 Dec 2011 at 4:49pm
I've got a D17d that I put a set of rings and bearings in it. The expence wasn't all that bad compared to the value of the tractor. The old girl runs good and the two speed had clutch makes for a handy tractor. First priority is, as others have said is an evaluation of that stuck motor. My favorite trick is PB Blaster in all pistons, two cans, one third in each cylinder should do it. With the tractor in nuetral, engage the pto, put a wrench on the shaft at the 10 or 2 oclock position and hang a 100lb suitcase weight on the end of the wrench. The next morning put her in fourth and rock it for about five minutes, put the wrench back on the other side this time and repeat that night after work. If in four or five days it doesn't free up, then you probly in for a total rebuild, sleeves, pistons and all. Please don't cut up a clasic like that there are pleanty of old bones for that. Good luck and let us know.
------------- 310, 2 B's, C, 2 WC's, 2 WD's, WD-45,D-14, D-17 gas, D-17 d IV, 190
Posted By: Orange Blood
Date Posted: 14 Dec 2011 at 5:04pm
Well since in some areas a running diesel in that shape sells for around $1500, you don't have a lot to play with. I can never bring myself to sell anything A/C Orange, no matter what shape it is in. If you can part with things, then you can probably get 500 for it (my guess) or you can spend 5000.00 and then have a real nice tractor. That may sound blunt, but it puts things in perspective.
------------- Still in use: HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7
Date Posted: 14 Dec 2011 at 5:40pm
Well there is no way I'm not going to put $5000 in it, so it will get repowered or I will keep a couple parts and scrap it before it leaves for $500. That might be all its worth as a tractor but its worth more than that as parts and scrap.
Posted By: Brian Jasper co. Ia
Date Posted: 14 Dec 2011 at 7:07pm
A Gleaner combine 230 or 262 gas would bolt right in. You'd need a governor from a D19. Unfortunately inexpensive and 262 diesel just don't go together. Doing the 6cyl gas conversion would give you a power house.
------------- "Any man who thinks he can be happy and prosperous by letting the government take care of him better take a closer look at the American Indian." Henry Ford
Date Posted: 14 Dec 2011 at 7:39pm
Denis in MI wrote:
Well there is no way I'm not going to put $5000 in it, so it will get repowered or I will keep a couple parts and scrap it before it leaves for $500. That might be all its worth as a tractor but its worth more than that as parts and scrap. |
You are absolutely correct, as a non running diesel complete tractor it isn't worth much, but to us guys restoring one, and not wanting to drop 5 grand in ours, good used oem parts are hard to find, and worth a decent price, hence the 5K bill. So if you want to make a few bucks part it out, that's what I always "want" to do to the extra ones I buy, but haven't yet brought myself to do it yet. I've been thinking about doing it to the green ones, I have no problem making money off them green guys, and don't like the tractors anyway. :-)
Date Posted: 14 Dec 2011 at 7:55pm
Well if anybodies interested its listed in the classifieds
