Print Page | Close Window
POLITICALLY INCORRECT 190XT
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=41098
Printed Date: 29 Aug 2025 at 3:33am
Topic: POLITICALLY INCORRECT 190XT
Posted By: tbran
Subject: POLITICALLY INCORRECT 190XT
Date Posted: 25 Nov 2011 at 4:49pm
CAN YOU SPOT HOW MANY CHANGES HAVE OCCURED SINCE 1965?
Posted By: JERRY-KS
Date Posted: 25 Nov 2011 at 5:09pm
Unit has engine from 7020 or L2-M2 combine @ 145 HP converted.  Involves after-cooler & also Has pisto (Simms) injection pump & wierd Hyd. filter.  Back of axle mount is reinforced. Frame rail shaved for oil filters & obvious rad. hoses in different place & exhaust as well.   JERRY-KS
Posted By: tbran
Date Posted: 25 Nov 2011 at 5:48pm
a 'saved from the scrap yard' unit . Jerry - very good - close - BTW it is a 72 L combine eng, 7020 intercooler - and the front cover was NOT changed to accept the 190 early style hyd pump - top secret way to do this.  This is a 2 yr project, kind of like Johnny Cash's caddy one piece at a time  1 hour at a time, from left over parts.  Filter is from some field campaign gone arwy from Agco /MF  and installed as eng filters blocked the origional pathway.   Hood and radiator had to be raised and relocated.    38" rear tires. Clutch linkage was a bear. Front end reaised to clear pan.  Throttle cable and shut off were a challange as well.  Some one has turned the pump - our small dyno didn't hold it nor would the clutch - it is retired to pulling a wagon so hp won't be a strain on anything.  IT is like the one I cut my teeth on in the 60's.  Saved it for old times sake .
Posted By: SteveM C/IL
Date Posted: 26 Nov 2011 at 1:20am
What is the big long tube under the aftercooler? Never seen one of those although I've only seen one L engine(2900) and that was on the pump side.
Posted By: tbran
Date Posted: 26 Nov 2011 at 8:24am
That is just the way the 1972 2900 markII's were made.  Believe me it holds a lot of water and antifreeze in this tube which runs from the water pump to the oil cooler across the back to the entry point rh rear corner .  And oh  yeah, just noticed something - no place to put oil in - back to drawing board one more time.  Also as much maligned as the inline Simms were - this one works great - starts great too.
Posted By: skipwelte
Date Posted: 26 Nov 2011 at 9:24am
Yea, there wasnt much on the outside of them 72 L 426s that fit anything else.   Ive changed a couple of combines over to the later 426-lot of fab work.  I worked on one once where there was an electrical short in the tube thru the grain tank,  the throttle and fuel shut off levers would get hot.  That one  blew the bypass oil filter lid gasket and ran out of oil-it was toast.  Nice lookin tractor tran, I thought all those odd 426s went to the happy huntin ground!!
Posted By: injpumpEd
Date Posted: 26 Nov 2011 at 10:24am
that's a 301.
Posted By: Lonn
Date Posted: 26 Nov 2011 at 11:16am
Alternator is on the wrong side too.
Wink
I am a Russian Bot
