Print Page | Close Window
Lemons of all brands lets hear them!!!
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=39028
Printed Date: 15 Dec 2025 at 9:18am
Topic: Lemons of all brands lets hear them!!!
Posted By: Smokey Joe
Subject: Lemons of all brands lets hear them!!!
Date Posted: 16 Oct 2011 at 12:56pm
I'm going to say Internationals shift linkage and their location for shifters up here over there behind you come on can i say yay for Console Control by AC.
John Deere 00-55 series hydraulic system design charge pump inside tractor requires splitting to fix.
AC Rotary fuel injection pumps and shift cables 7000 series.
210,220,7010 AC,7020 AC,7040 AC,7045 Pedal Tractor, 8050& 8070 and Parts and Pieces of Many More!!!
Posted By: Orange Blood
Date Posted: 16 Oct 2011 at 1:08pm
Let's not bring our selves down to the same level as those on other sites!!  Please!  All manufactures have issues, it's the nature of the beast.
Still in use:
Date Posted: 16 Oct 2011 at 1:27pm
I just like ruffling feathers I want to see some of the Red Power guys posting "did you see what that guy said on the AC site" They said IH only messed up 1 tractor and that the 560.Ha Ha Ha.
Posted By: AC WD45
Date Posted: 16 Oct 2011 at 1:34pm
Oh come on this might be fun
Allis Chalmers:
Wd45's hydraulic pump is a pita to remove service. Torque housing fill plug is in a very tight spot. 3rd gear jump is common
D series: 3rd gear jump is common, power directors wear out
7000 Series:
Short engine life
John Deere:
A's blow head gaskets all the time
B's the same
Hand clutch linkage sucks
Styled tractors had weak frames
Power-trol really was a troll.
**20 series burn up powershift,
Synchro tractors, burn up clutches
Quad range tractors always lose 1st and second slap shift.
Kubota:
Burn up Clutches
Cub cadet:
 horrible garden tractors
Farmall/IH:
Horrible shift locations for almost ALL models, Throttle linkage is horrible on all letter series, Axle housings split, axle shafts and keys shear, starting procedure is ridiculously stupid on letter series, IH 300/350 series always bend/break steering rods
Ford:
select-o-speed blows, literally and figuratively
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Posted By: Josh Day
Date Posted: 16 Oct 2011 at 2:10pm
Just like Orange Blood said " All manufactures have their issues".
But AC's don't have any issues. LOL
Posted By: Doyle B(NY)
Date Posted: 16 Oct 2011 at 3:06pm
Ahhhh geese you gone done opened of up a can of worms now...
welll... seens its already started
AC jump outta 3rd, 190s weak rearends, very weak front ends
John deere 20 series powershift burns out
IH junk shift linkages and horriable fuel economy
ford select o speed horriable
Posted By: Dick L
Date Posted: 16 Oct 2011 at 3:28pm
Alls o mine are lemmons even when nothing is wrong with them.
Posted By: acwdwcman
Date Posted: 16 Oct 2011 at 4:16pm
ih: 560's suck!!!
 and for ac's i agree with josh
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Posted By: powertech84
Date Posted: 16 Oct 2011 at 4:25pm
Cant think of a single transmission from ac that anyone could really be proud of. They all seemed to have issues staying in gear or just too weak in general
Posted By: AllisFreak MN
Date Posted: 16 Oct 2011 at 5:33pm
Can't forget IH's illustrious "Torque", either out or soon to be out.
JD's 30 years behind the rest of the industry's 2 cylinder engine.
Ever try to graciously back up to hitch up something with a JD 60 hand clutch? There's like 4 feet of travel in the lever and you have to push it forward (about 4 feet) to go backwards. You can't see the hole in the drawbar and the tractor is jumpy as heck to boot. I guess a true JD man can probably do it in his sleep, Being an AC man I think they suck.
Date Posted: 16 Oct 2011 at 5:50pm
I disagree with you on that statement cause I really like the power director in the 7000&8000 series they are tough I got one in a 7020 hot stock tractor that has a 426 in it and it has about 35 pulls on it at about 300-400HP and no issues and no gear trouble.
Date Posted: 16 Oct 2011 at 6:02pm
I know of no tranny issues caused by bad engineering, yes there were some weak rearends.  This whole jumping out of gear is from the user, maybe not you, but someone in the past grinding gears.  You grind gears in any tractor and eventually the tranny is shot.  The power directors are pretty solid too.  Yes there are issues that Allis had, but many if not most of the tranny problems resulted from operator error.  You can build them only so tough, before something else won't hold up, or the engine can no longer drive all the weight.
Between my dad, uncle, granddad, and many of my cousins, we probably own near 150 different Allis, from the WC up to the 8550, and my uncle now owns some of the Agco stuff.  Except for the control cables on the 7000 series, none of them have had a cronic problem.  Doesn't mean stuff doesn't break and we had to fix it, but it was either our own fault, using the tactor for something it wans't intended, or just worn out, but it wasn't like the same thing on every similar tractor we owned went bad.
All manufactures have it, the only thing I can think of that truely hinges on a design flaw, is our neighbors brand new 9400 JD combine would eat two or three clean grain augers every harvest, JD engineers came out, and could never figure it out, don't know if it was unique or a trend in the line.
Still in use:
Posted By: D-allis Iowa
Date Posted: 16 Oct 2011 at 6:55pm
Parking brake on 185 and others of that era. The WC hand brake had a very good safe parking brake and each side was locked in to its max. I had a near new 185 roll down a hill when parking beake with its little teeth sliped and rolled into a new milking parlor. Partially my fault should have wheels cocked more but never. Really learned a good lesson. Parking brake cables on 8050 also could be better.. Other than that don't have many complaints about Allis.
Posted By: Brian Jasper co. Ia
Date Posted: 16 Oct 2011 at 9:13pm
Allis Chalmers:
7000 Series:
Short engine life
John Deere:
B's the same
Kubota:
Burn up Clutches
Cub cadet:
Farmall/IH:
Ford:
Cub Cadet horrible? You're talking after MTD got them right? The older IH CC's are tanks...
Posted By: CTuckerNWIL
Date Posted: 16 Oct 2011 at 9:30pm
I've been around Allis tractors for 58 of my 58 years and never knew of one with that had issues staying in gear until some idiot spent 10 or 20 years grinding it into 3rd.
Posted By: Reeseholler
Date Posted: 16 Oct 2011 at 10:40pm
Well.
I've never had a problem with my A blowing head gaskets. I do agree that the clutch linkages on the deere's wear out. With a little bit of patience they can be fixed.
I've never had a problem with my TA either. Yes I do use it....
Not sure what you meant by the farmall letter series starting procedures. If you mean the diesels, I guess it takes some getting used to. I love my diesels.
The tranny on my allis has never gave me a problem at all.
Now,
For me, seems like a lot of rear axle seals on the allis's leak. On the older lettered that is.
I think the 560's overall were flops. They looked nice, but IH should have had their act together.
I think the way to engage the PTO on a JD 730 is a pain in the butt.
I'm really not biased with my collecting tastes....
Posted By: SHAMELESS
Date Posted: 16 Oct 2011 at 10:42pm
IH's ta...costs about $1.00 each time you use it, and the side shifter costs a bunch when it locks in forward and park at the same time! the shift and hyd cables on AC's snap to easy! the kabota clutches are junk, the ford select-o-matic...don't even go there! ford 8-N & 9-N's are people killers!, 3rd gear (always used) in AC's are not strong nuff, JD 2 puffers jerk you and all PTO equipment dies prematurly from the jerking! the 20 series JD's had bad wiring that wanted to melt and catch fire all the time!, switching PTO's were a joke! PTO's on the 3 numbered AC models are to weak, IH 460/560 hard to git on and off of with the tall levers on each side, JD's from 20 series on up burn almost twice the fuel as others, the old case's sucked when trying to hook a belt up to anything belt driven as the pulley ran all the time, always took 2 persons to hook up....one to hold a 2x4 against the belt to keep it on the pulley while the other backed the tractor up! these are just some of the tractors i've had the pleasure and displeasure of operating in my life so far!
Posted By: 79fordblake
Date Posted: 17 Oct 2011 at 12:34am
John Deere:
B's the same
Well since I am a John Deere and Allis man I gotta say something.....lol. I have never seen an A or B blow a head gasket when it was installed correctly.....I have 3 A's myself.....haven't ever seen A's pushing 50+ HP blow a head gasket either. The clutch linkage is very very simple and easy to fix the areas that wear out. Not all styled tractors had weak frames b/c not all styled tractors have pressed steel frames......and I've never had a problem with the JD Power-trol.......John Deere just must not like you.....lol.
Posted By: ACFarmer
Date Posted: 18 Oct 2011 at 8:04am
Wide fronts under the 180-185-190s were too weak......
Making a living farming with and working on Allis Equipment
Posted By: Charlie175
Date Posted: 18 Oct 2011 at 8:50am
at one of the local shows I watch a guy hook up a wagon to a JD720, looked awkward at best but he got close and luckily the wagon hitch had one of those extenders that the ground guy was able to slide out and hook up.
I found out that IH 300 Utility steering boxes are junk
AC had weak brakes on a lot of tractors series.
Charlie
Posted By: injpumpEd
Date Posted: 18 Oct 2011 at 10:14am
I've been following this topic over on rpm as well. I have been around AC, JD, & IH as a kid growing up on the farm, then worked in 2 different White dealers. they all have their issues!
Posted By: Kcgrain
Date Posted: 18 Oct 2011 at 10:58am
I wonder where some of this is coming from, 7000 series short engine life?? Not something I have expierenced, the 7080-7580 had crank problems but it wasnt caused by a bad engine the crank was overhardened and made the ends brittle, common sence would tell you when the crank breaks the nose off its not a engine power problem there is no hp other than acc. drive on the front of the engine, now if the rear broke now thats an engine issue.Tranny problems, we have seen tractors with 20,000+ hrs that had no tranny issues, if your going to grind gears and not keep the fluid levels correct any brand is going to have an issue. The early 7000 series had cable breaking problems the later 7000 and all 8000 had HD cables so that isnt an issue they just needed to be updated, and adjusted properly. The AC tranny and rearend combo was one of the most bullet proof combos made.The front ends on 180-190 tractors were weak? Where? You cant find a IH where the whole front end isnt all wobbled out and broke, any JD 10-20 series if it had a loader on the knees were broke off the bolster, and rewelded, and alot that didnt have a loader on were broke, when was the last time you seen a knee on the AC broke, Ive never seen it, the back ends have been broke or cracked but there again no body greased it the pins are all slopped out and when you go threw a hole its getting a sudden jolt, tighten them up with new pin and grease them and they will last forever.Not saying AC didnt have flaws, but in comparison to the others on the market they were as tough as elephant nails!!!!
Posted By: Steve M
Date Posted: 18 Oct 2011 at 12:23pm
I'm guessing that Dick L has a lemon for a wife also:)
Posted By: KGood
Date Posted: 18 Oct 2011 at 1:25pm
Well put Kcgrain Trannys are still made that way in vehicles today they just have sycronizers so they don't gring and they say there was less hp loss through that style. I just haven't had the problems that have been stated. It took my buddy 3 parts H's(IH)to find enuff unbroken gears to fix his and it still jumps out of 5th. I've got a 930 case I got cheap because of a tranny problem that left it dead in the field the guy was told it needed split to fix and the local caseih dealer said it cost more than it's worth. I seen a 4010 deere torn apart with a broken pinion gear etc.
Posted By: R.W
Date Posted: 18 Oct 2011 at 1:32pm
Seems kinda funny that all you die hard Allis Chalmers guys know alot about the "other brand"?
Posted By: Austin(WI)
Date Posted: 18 Oct 2011 at 1:41pm
What was the point of the proving grounds at these places then? ( AC, JD, IH, MM) whatever... I think these companies all had the intentions of building and selling a top notch machine. Maybe a few here and there had flaws. BUT that goes for anything you buy! People saying how AC tractors are notorious for jumping out of gear... WHEN? Now or back in 1959 when the D14 came out? If there was a problem there was more than likely some memo sent out by AC to dealers and the owners stating the problem and how they were going to fix it. Same goes for things like cars now days. If you look at the gear problem from today's stand point...it is useless. That tractor is 50 years old; something is eventually going to go out on it from the wear and tear. I have read how some people have never had problems either! So it also goes to show that it is how the machine was handled by previous owners before you got it. I think tractors were built tough and competitively
"Better By Design"
Posted By: Dick L
Date Posted: 18 Oct 2011 at 1:55pm
Must have a broken fish pole. Whipped out the hook and it took all that time to get a bite. (:^D
Posted By: Josh Day
Date Posted: 18 Oct 2011 at 4:25pm
What about CASE?
Posted By: Josh Day
Date Posted: 18 Oct 2011 at 7:13pm
bump
Posted By: norm[ind]
Date Posted: 18 Oct 2011 at 7:23pm
  case --can,t afford something else
  a-c quit making 2 cyls. in 1930   took john deere 30 yrs to figure that out
Posted By: j.w.freck
Date Posted: 18 Oct 2011 at 7:44pm
mr.tucker said it all.99% of the troubles are usually attributed to misuse.i have 11 wd 45,s gas and diesel.none of them jump out of gear or have any gear rumble.one of the issues i have found on the tractors was it seems that no one would take the time or effort to service the oil bath air cleaner.i have had to chisel the dirt and chaff out of some of them.the main reason for transmission problems were operators shifting gears with the hand clutch.YOU DONT DO THAT.no matter what some people say and do.i am in my mid 70 s and have been around and operated several brands and various models.the old wd-wd45 was a tough and well built machine for its day.i know they made us a good living on the farms back in ths 1950 s...
Posted By: AC WD45
Allis Chalmers:
7000 Series:
Short engine life
John Deere:
B's the same
Roll-o-matic sucks
Kubota:
Burn up Clutches
Cub cadet:
Farmall/IH:
Ford:
Yes. After MTD took over. My 2009 lasted a year. heard nothing but complaints about them.
German Shepherd dad
#WD234847
#WD88193
Posted By: Todd AL
Date Posted: 18 Oct 2011 at 8:15pm
Why do you think they switched to Allis?
Posted By: R.W
Date Posted: 18 Oct 2011 at 8:23pm
I thought of that after I posted.
Date Posted: 18 Oct 2011 at 9:01pm
I agree with some of the other post all companies have their flaws. None of them were perfect. I personally like Allis-Chalmers and John Deere and I own both brands.
I don't really care for Farmall or Oliver.......but I am not saying they are bad.....I see to many people that have them and have great success with them.
Any tractor that can survive for over 50yrs is a good tractor. The old ones will always be around....all the new stuff will go to the scrap yard when its wore out.
