Print Page | Close Window
190XT expert required
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=191290
Printed Date: 01 Apr 2026 at 5:50pm
Topic: 190XT expert required
Posted By: youngorange2000
Subject: 190XT expert required
Date Posted: 15 Oct 2022 at 7:52pm
anyone know what these two welded shut lines are for they are located in front of the passenger side brake assembly. Thanks in advance
Posted By: DSeries4
Date Posted: 15 Oct 2022 at 7:59pm
Can you zoom out for a better shot?  The entire hydraulic valve body is in front of the brake assembly.
Date Posted: 15 Oct 2022 at 8:07pm
This is located about 6 inches behind the main hydraulic spools and pd valve
Posted By: Lynn Marshall
Date Posted: 15 Oct 2022 at 8:15pm
That's the PTO valve body.
Posted By: Alex09(WI)
Date Posted: 15 Oct 2022 at 10:23pm
resized picture*
My best guess is someone removed the hyd pto clutch from the torque tube and capped off the lines from the pto valve.
www.awtractor.com
A&W TRACTOR 920-598-1287
Date Posted: 17 Oct 2022 at 6:05pm
Is it possible my tractor had a hydraulic pto at some time? It has a decal on the side of the counsel for the PTO but no lever it has the pull knob on the floor
Posted By: DrAllis
Date Posted: 17 Oct 2022 at 6:24pm
The valve is there. So, they removed the lever.
Date Posted: 17 Oct 2022 at 6:52pm
Is it possible my tractor has both types of PTO? If so why would they disable the hydraulic pto?
Date Posted: 17 Oct 2022 at 8:20pm
For simplicity's sake, it is not possible to have both. You have 1 or the other. If you still had the hyd pto clutch, your pto would not work because there is no hyd pressure to engage it, regardless of moving the knob by the platform.
The hyd pto enables the operator to engage and disengage the pto independently of the foot clutch. It is not live PTO, because you don't have to use the foot clutch to engange it. And its not really independent PTO because in an emergency, the operator can use his reflex to slam in the clutch pedal to stop all powered motion. I might label it as semi-independent pto??
www.awtractor.com
Posted By: DSeries4
Date Posted: 17 Oct 2022 at 8:21pm
You would have to ask the previous owner why they disabled it.  Only they would know.
