Print Page | Close Window
WD45 carb
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=182540
Printed Date: 26 Aug 2025 at 5:39am
Topic: WD45 carb
Posted By: Dan Hauter
Subject: WD45 carb
Date Posted: 15 Aug 2021 at 12:53pm
My WD45 was running just fine then started missing & cutting out.  A retired mechanic checked it out & said he thinks it's the carb. Probably has dirt or crud in it. I have the carb off and in a bucket.  What's the best way to proceed?  Soak it in carburetor cleaner then blow it out with an air compressor?  Please & thanks for advice.  Dan.
Posted By: Ted J
Date Posted: 15 Aug 2021 at 1:10pm
Dan, I'm a novice when it comes to these carbs, but I know NOT to blow air through them as you might collapse the float.
There are a lot of threads on here about cleaning etc. these carbs.  You just need to do a search.
I just did a seach and came up with these.  This is just one page of 10.  Don't know if this link will help or not, but this is where I did my search.
https://cse.google.com/cse?cx=004370602758429918820:8ofivf40joo" rel="nofollow - https://cse.google.com/cse?cx=004370602758429918820:8ofivf40joo
Here are the results of page 1
https://www.allischalmers.com/forum/cleaning-a-carb_topic155558.html" rel="nofollow - Cleaning a carb
https://www.allischalmers.com/forum/electrolysis-to-clean-carb_topic48882.html" rel="nofollow - Electrolysis to clean carb?
https://www.allischalmers.com/forum/carb-cleaning-kit_topic28989.html" rel="nofollow - Carb cleaning kit?
https://www.allischalmers.com/forum/d17-issue_topic140448.html" rel="nofollow - D17 issue
https://www.allischalmers.com/forum/model-b-carb-issue_topic129474.html" rel="nofollow - Model B Carb issue
https://www.allischalmers.com/forum/allis-b-carb-question_topic40101.html" rel="nofollow - Allis B carb question?
https://www.allischalmers.com/forum/allis-b-carb-question_topic40101.html" rel="nofollow">Thumbnail image
https://www.allischalmers.com/forum/ca-carb_topic9672.html" rel="nofollow - CA Carb
https://www.allischalmers.com/forum/help-with-b-carburetor-settings_topic142643.html" rel="nofollow - Help with 'B' Carburetor settings
https://www.allischalmers.com/forum/carb-advice_topic167176.html" rel="nofollow - carb advice
https://www.allischalmers.com/forum/wd45-carb-problems_topic39154.html" rel="nofollow - WD45 carb problems
Otherwise, Steve B&B is one of the pros on here.  Others will chime in also.
GOOD LUCK!!
Date Posted: 15 Aug 2021 at 2:09pm
Thanks!  I'll check out those posts.
Posted By: sadmyentist
Date Posted: 17 Aug 2021 at 8:33pm
These are very simple carbs. Like a giant lawnmower carb, really. I don't think you will have any trouble taking it apart, slicking stuff up and putting back together. Only thing you need to watch is getting the venturi tube the right way up.
You may also want to pop off the distributor cap and see how much play the rotor has. I had similar problems twice. For one the distributor was shot and I bought a beautifully reconditioned one from Steve in NJ. ( https://www.bb-customcircuits.com/" rel="nofollow - https://www.bb-customcircuits.com/ )  For the other I just had to torque the nut that holds the spiral cut gear that drives the distributor. If that gear can move on the shaft, it changes the timing and can cause all sort of weird coughing and spitting.
Date Posted: 17 Aug 2021 at 8:34pm
Also of note - the WD45 likes you to keep the sediment bowl CLEAN.
Posted By: WF owner
Date Posted: 17 Aug 2021 at 8:51pm
Dick L, a while back, said that he "boils' carburetors. I tried Dick's method.
First, I take the bowl off the carb and take the float out. I clean up any obvious crud.
I have an old hot plate from when we redid our kitchen a few years back and a pan I rescued from a garage sale. Everything but the float goes into a pot of water and bring it to a rolling boil, then shut it off. As soon as it is cool enough that I can handle it (with pliers or gloves), I take it apart. The seats and screws seem to come out much easier, when they are still warm and it really cleans the carb up pretty well.
I have used this method several times and it works for me. Thank you Dick L !
