Print Page | Close Window
D 15 fuel tank/hood webbing
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=182474
Printed Date: 14 May 2025 at 6:06am
Topic: D 15 fuel tank/hood webbing
Posted By: ACinSC
Subject: D 15 fuel tank/hood webbing
Date Posted: 12 Aug 2021 at 10:40am
Looks like the underside of my hood had some webbing on it at some point . What do you fellas use , or do you just order some ? THANKS !
Posted By: Phil48ACWC
Date Posted: 12 Aug 2021 at 1:39pm
Old Seat Belt. Cut to required width and carefully burn cut edge with propane torch
Posted By: Goose
Date Posted: 12 Aug 2021 at 2:08pm
I just use that white Styrofoam plastic-like material used in wrapping something for shipping. It is soft and cushion-like. I put that between the hood and gas tank and it prevents wear and gives it some paint protection.
"People are human beings, produced by the society in which they live. You encourage people by seeing the good in them." ~ Nelson Mandela
Posted By: Goose
Date Posted: 12 Aug 2021 at 2:11pm
This is the stuff I use. It works great. You probably can buy it at any hardware or box store like Walmart, Target, etc.
https://www.ebay.com/itm/313083129230?hash=item48e5356d8e:g:e50AAOSwIrteva9M" rel="nofollow - https://www.ebay.com/itm/313083129230?hash=item48e5356d8e:g:e50AAOSwIrteva9M
Posted By: ACinSC
Date Posted: 12 Aug 2021 at 2:22pm
Thanks for a couple good ideas !
Posted By: Allis dave
Date Posted: 12 Aug 2021 at 2:49pm
I walked around walmart and finally stopped in the camping section and found something with a long nylon strap. something like a shoulder strap.
I'm looking for something bigger now. My D17 had about an 8"x8" share that glues tot he side of the hood to keep it from getting too hot form the muffler.
Posted By: steve(ill)
Date Posted: 12 Aug 2021 at 3:12pm
heat shield from NAPA or Auto Zone
Posted By: ACinSC
Date Posted: 12 Aug 2021 at 3:35pm
Brings to mind many years ago the plumbing supply store I worked at sold asbestos in a roll . I used some to wrap around my starter to keep the headers from cooking it . Seems pretty crazy now . Thanks !
Posted By: Boss Man
Date Posted: 12 Aug 2021 at 3:48pm
The only problem with foam is it will trap condensation and cause rust. The cloth webbing will allow it to dry out.
Posted By: DiyDave
Date Posted: 13 Aug 2021 at 4:40am
Boy scout canvas belt is pretty close...Wink
Posted By: Kenny L.
Date Posted: 13 Aug 2021 at 5:07am
I use the strap from a tie down strap that I've taken out of service
Date Posted: 13 Aug 2021 at 6:53am
Thanks guys!
Posted By: Charlie175
Date Posted: 13 Aug 2021 at 7:03am
I had some left over no slip drawer stuff. Not sure what it is called, kind of rubbery mesh pad that you can put in drawers or on the floor to keep rugs from slipping. I just cut a long strip and used that. It has worn well.
Charlie
Posted By: ACinSC
Date Posted: 13 Aug 2021 at 8:16am
Found some of the white foam stuff that I had saved . May use it and see how it holds up . Thanks for all the good ideas !
Posted By: ACinSC
Date Posted: 13 Aug 2021 at 5:38pm
Thanks Goose . I used that white foam stuff . Gotta be better than it was .
