Print Page | Close Window
3 pt sub-soiler on 53 wd-45
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=170134
Printed Date: 16 Dec 2025 at 8:00am
Topic: 3 pt sub-soiler on 53 wd-45
Posted By: Bruiser
Subject: 3 pt sub-soiler on 53 wd-45
Date Posted: 14 Apr 2020 at 5:57pm
Ford IO-89 new to me from consignment auction last Sat.  Put it to work today and am real happy with the results.  Waiting for the pictures.
Posted By: Sugarmaker
Date Posted: 14 Apr 2020 at 6:18pm
Folks,
 Here you go!
Posted By: Gary Burnett
Date Posted: 14 Apr 2020 at 9:18pm
No top link?
Posted By: Bruiser
Date Posted: 14 Apr 2020 at 9:42pm
Just had it setting there to get pins and link after I brought it home.  Tried it out today just to use on some lanes we use in the off season but will be planted to corn.  Pulled good deep as it would go with power and traction in second gear.  The ground really bubbles up about a foot on each side of the shank.  Worked better than I thought it would usually the other way around for me.
Posted By: Robert Mull Sr Georg
Date Posted: 17 Apr 2020 at 8:30am
When that one bolt breaks that holds the top on don't I repeat don't replace it with a grade 8 bolt as my Dad did. Use a grade 5 it is a shear pin. Bent the heck out of the shank the next time he hit a rock.
Posted By: jaybmiller
Date Posted: 17 Apr 2020 at 8:33am
I must have an 'original' A-C subsoiler...NO bolts or shear pin...
It's a one piece 'fishhook' looking subsoiler....
good thing there's NO big rocks in the wife's garden !
have no idea what model it is.... does a GREAT job though !!
Jay
Posted By: mhankins
Date Posted: 17 Apr 2020 at 8:52am
How is the tractor top link attached to the tractor?
 Mine looks to be a home made 3pt and the top link pivots with the lift arms.I would much prefer it to be stationary like a traditional 3pt.
Posted By: DiyDave
Date Posted: 17 Apr 2020 at 5:58pm
Believe it or not, that's the same one, I pull, with a 22 HP Kubota!  A lot slower, I might add!  And it only clears the ground, a coupla inches, when fully raised, but it does the job!Wink
Posted By: Bruiser
Date Posted: 17 Apr 2020 at 10:31pm
Mhank if you look close you can see the top link bracket above pto cover it has 3 hole choices and yes when fully raised it's only a couple inches off the ground.  Thankfully no rocks here but could always be a tree root.
