Some more nos parts ????
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=167160
Printed Date: 01 Jun 2024 at 12:48am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Some more nos parts ????
Posted By: Mikez
Subject: Some more nos parts ????
Date Posted: 05 Jan 2020 at 11:10pm
Hi everyone Have a few questions for you guys on some parts.
First is some washers 202701 this number isn't in my book, there in sealed bag, if you can't find the number I'll open an measure them.
Second are these springs 230282 my book says fits G160,G-138,G-149,D14aux. These are power units right, does it fit D14 tractor.
Third are these key switch 225310 says fits bunch of tractors including D14 but in our book and tractor has different switch, just woundering if it fits D14
Thanks for the info
Posted By: orangereborn
Date Posted: 06 Jan 2020 at 1:28am
225310 I think should fit early D14.....Spring should fit D14.....Are not the washers 2027010? Maybe simplicity??? Not real sure on that...
Posted By: Matt (Jordan,MN)
Date Posted: 06 Jan 2020 at 1:53am
2027010 is a lawn & garden part number.
------------- Owner of Matt Scott LLC Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/
Posted By: Mikez
Date Posted: 06 Jan 2020 at 9:14am
Yes duh sorry I should have cought that. I see it after you said it on the washer. Our D14 has that odd shaped key with a larger switch and more terminals. Would that switch have been used with the push button start. Thank you guys
Posted By: JimIA
Date Posted: 06 Jan 2020 at 12:13pm
225310 is just a two position switch. It was used on later WDs, WD45s, CAs, Bs etc. Im sure it was used on D14 power unit engines but not on the tractors.
------------- An open eye is much more observant than an open mouth
Posted By: Mikez
Date Posted: 06 Jan 2020 at 1:06pm
Posted By: Gary
Date Posted: 07 Jan 2020 at 12:54pm
The spring 230282 does fit D-14 Tractor per Parts Catalog Page 17.
It is the 'surge' spring that attaches to the Rod between Carb and Governor Lever.
Gary
