Print Page | Close Window
WD45 Flat Top Pistons
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=166419
Printed Date: 18 Dec 2025 at 8:49am
Topic: WD45 Flat Top Pistons
Posted By: Farrell(Utah)
Subject: WD45 Flat Top Pistons
Date Posted: 07 Dec 2019 at 10:38am
.  Several weeks ago I made a post about finding overbore flat top pistons in one of  my WD45 tractors.   Yesterday, I pulled a piston out and found that it is not an AC piston.  The markings are WMW A 1070.  As I understand, this stands for White Machine Works.  Does anyone know anything about these pistons such as compression, HP, etc.?  Are rings still available?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Posted By: AaronSEIA
Date Posted: 07 Dec 2019 at 11:29am
Google search shows that WMW eventually became Clevite.  Not sure if or how that helps.
AaronSEIA
Posted By: Alvin M
Date Posted: 07 Dec 2019 at 1:57pm
Hastings Calls It A White Machine Piston # A1070 Use Ring Set # 2C7553   4 1/8 Bore
Date Posted: 07 Dec 2019 at 2:16pm
    Thanks very much you guys.  Looks like it can be reprinted.
Posted By: DaveKamp
Date Posted: 07 Dec 2019 at 5:05pm
Aside from the shape of the piston top, you should measure the piston height... meaning, distance from the top of the piston edge to the center of the wrist pin.  When comparing pistons, the dome, flat, or dish is only PART of the piston's end displacement-  the piston height shows the rest.
It is very possible that an aftermarket flattop could exhibit same, or less compression than a factory dished piston.
