Print Page | Close Window
New Rear Tires: BKT vs Firestone
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=164757
Printed Date: 14 Dec 2025 at 11:34pm
Topic: New Rear Tires: BKT vs Firestone
Posted By: BigGuy1000
Subject: New Rear Tires: BKT vs Firestone
Date Posted: 02 Oct 2019 at 5:15pm
I am being quoted about 150 more for Firestone over BKT for 18.4 by 34 on my Allis.  Opinions and especially experience wanted here, are Firestones worth the extra here???
Thanks!
Posted By: exSW
Date Posted: 02 Oct 2019 at 5:58pm
Yes.
Posted By: NomoreJohnDeere
Date Posted: 02 Oct 2019 at 6:10pm
for 150 yes
which firestone?
HD3
Posted By: acd17toy
Date Posted: 02 Oct 2019 at 6:23pm
 In my option the BKT is the better tire.  Wider bars for the tread, heavier side walls, better all around traction in all conditions. Have two sets of rears on  my tractors, one pair is about 8 years old and still looks like new.
Posted By: jaybmiller
Date Posted: 02 Oct 2019 at 7:01pm
What kind of use will they be getting ? What are they rated for ( hours of use ?) Are they IDENTICAL ( weight cap, traction, etc.).
I lay odds some of my D-14 rubber is original though I don't need much on 1 acre !!
Jay
Posted By: DougG
Date Posted: 02 Oct 2019 at 7:26pm
Go for the Firestones in my opinion,, I bought a 190 that has brand new BKT 34,s on it and one is clearly 2 inches taller than the other setting on level concrete,, same air pressure etc,, its not that much money for the differece
Posted By: SteveM C/IL
Date Posted: 02 Oct 2019 at 8:19pm
For the little difference, I'd get the real thing
Posted By: DSeries4
Date Posted: 02 Oct 2019 at 8:27pm
$150 Is nothing!  Firestone's are $600 more expensive than BKTs for the 24.5 x 32s on my D21!  That is for one tire only!  Much as I like Firestone, guess which ones I am going for.
Posted By: wayne IA
Date Posted: 02 Oct 2019 at 8:52pm
One thing to check on the Firestones is the tread bar width.  They make a thin barred tire that is thinner than the regular tires and thus cheaper.  If it is the wider barred Firestone, then I would go with the Firestone.  You know the cheap Firestones when you see them in the flesh, I have a friend that has them on a tractor of his.  They seem to work fine, but you know they aren't going to wear nearly as long.  Another friend has the BKT tires on a 7810 Deere of his and they seem to be a good tire for the money.  My preference is for the Firestone though.
Posted By: Walker
Date Posted: 02 Oct 2019 at 9:13pm
Where I got mine called em Burger King tires and so far upwards of 10yrs later I've no complaints what so ever. If the truth were known both names are probably from the same rubber compound and the same mold.
Posted By: BEK
Date Posted: 03 Oct 2019 at 6:51am
I have BKT's on the rear of my B and WC. Decent tire at a fair price. No complaints.
Posted By: Sugarmaker
Date Posted: 03 Oct 2019 at 6:54am
Had a pair of the BKT's (13.6-28) Were good tires.
Posted By: tomstractorsandtoys
Date Posted: 03 Oct 2019 at 7:09am
I have a Deere 4020 with the Firestone 23 degree non radial tires. They have been on for close to 20 years and for the first 10 it was my big tractor. They are now worn smooth. Talked to my tire dealer about new ones and his reply was you are not going to like them. They changed something and even though they look the same you are only going to get half the wear out of the next set. Not sure what I am going to buy but need something before spring. Tom
Posted By: festus51
Date Posted: 03 Oct 2019 at 7:29am
I agree with Doug.   I have 38"  bkt beside a 34" goodyear and the 34 is the same height as the bkt.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Posted By: Dakota Dave
Date Posted: 03 Oct 2019 at 7:47am
I've had BKTs on one of my WD45s for over10 years I'm happy with them. I stopped buying after the wilderness tire fiasco. I had three tires seperate on one touch in three months. Firestone wouldn't replace any of them claimed offroad tires aren't warranties. I contacted Firestone and informed them I'd never put a Firestone on again. By the time they did a recall on all wilderness tires I had replaced with Goodyears. I haven't put on a Firestone since. The farm I work at puts mostly firestones on the tractors they are neither bbetter or worse than any other tire. The Goodyear tracks seem to last longer.
Posted By: kinghunter
Date Posted: 03 Oct 2019 at 10:59am
Bkt on this farm. Last longer than Firestone’s I’ve had.
Posted By: ACinSC
Date Posted: 03 Oct 2019 at 2:05pm
Any ideas on how long it takes a tire to "toughen up" ? Seems to me that new tires are prone to punctures ? Thanks
Posted By: HD6GTOM
Date Posted: 03 Oct 2019 at 10:54pm
I sold both of these. BKT go on small or chore tractors. Firestones go on the tractor that goes to the field and works many hours.
Posted By: HD6GTOM
Date Posted: 03 Oct 2019 at 11:00pm
AC in SC. We would get in semi loads of Firestones in Jan/Feb. We would try to let them set outside for 3 months. This did the trick for Firestone. If we got in Titan/Armstrong, BKT, Alliance, Carlisle, etc we try'd to let them set a minimum of 6 months. You have to watch some of the cheaper brands. If they set outside too long, the sunlight will cause the inner liner to get brittle and crack in many spots. Then your tube will go to pieces.
Posted By: ACinSC
Date Posted: 04 Oct 2019 at 6:00am
Thanks Tom !!
Date Posted: 04 Oct 2019 at 6:22am
re: Seems to me that new tires are prone to punctures
That's because you now have TRACTION and drive where you never went before with 'baldies', like thorn infested windrows.....Cry
Posted By: Tbone95
Date Posted: 04 Oct 2019 at 7:04am
Put BKT’s on the combine 4 years ago. So far so good.
Posted By: ACinSC
Date Posted: 04 Oct 2019 at 7:54am
You may be right Jay . I do know that I took a brand new tractor where I'd had the old D 15 many times . Poked a hole in the new rear tire very soon . Thanks
Posted By: ezlle71
Date Posted: 04 Oct 2019 at 3:06pm
I put new firestone's on my 190XT this spring, wasn't cheap but we have had good luck with firestones on our farm here in the flint hills. Plus can't beat the service we have with our dealer. Called him 10 am, tires were on by 5:30. calcium and all.
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
