A/C 190 Air Conditioner
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=161957
Printed Date: 04 May 2025 at 1:06am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: A/C 190 Air Conditioner
Posted By: DaveH
Subject: A/C 190 Air Conditioner
Date Posted: 16 Jun 2019 at 5:53pm
Has anyone put an air conditioner on an A/C 190? I'm looking at a 190XT with a cab, but it doesn't have an air conditioner.Any guidance or experience regarding adding an a/c would be appreciated.
Posted By: SteveM C/IL
Date Posted: 16 Jun 2019 at 5:56pm
I was gonna put a cab on my 220 and fix it like you want to.....bought an 8070 instead and kept the 220 for backup. Something to consider.
Posted By: MACK
Date Posted: 16 Jun 2019 at 8:55pm
First thing is getting all the air leaks fixed and insolated to where the air-conditioning can over come the out side heat. MACK
Posted By: Brian Jasper co. Ia
Date Posted: 16 Jun 2019 at 11:06pm
I think I've heard of guys using a kit from Red Dot? Classic Auto Air has universal systems, one being big enough for a full size van. I would think that would cool a tractor cab on the hottest days. I would buy the largest capacity system I could find and do like Mack says and fix any drafts. Steele Rubber Products makes universal weatherstripping for doors and windows. Something else to consider is insulation. Lizard Skin is a spray on insulation and they also have a sound control coating as well.
------------- "Any man who thinks he can be happy and prosperous by letting the government take care of him better take a closer look at the American Indian." Henry Ford
Posted By: Dakota Dave
Date Posted: 17 Jun 2019 at 7:46am
We put Red Dot ACs on 10 box vans it would cool down a Chevy van with a 12' box so I'm sure it'll cool down a little tractor cab even with air leaks and no insulation. Having 10 trucks done I got them down to $2500 per truck so it ain't cheep.
Posted By: calico190xt68
Date Posted: 17 Jun 2019 at 8:11am
I have a stolper cab on my 190xt and I investigated this a bit. There is a picture on this forum that I found shows a guy that did this. I tried to find out details but got no response. You have a spare pulley to use to power the compressor with a belt but you have to make a bracket to hold the compressor. I believe it has to hang out the side and he had to cut the shield to make room for the belt. The other issue that I have heard mentioned is getting an AC unit that will cool it down. I was going to use a vintage car version but was not convinced even with some insulation it would cool it down. The cost to do the AC was going to be nearly as much as I paid for the tractor. I believe those RedDots are good as mentioned above and the best solution. I ended up buying a 7010 with working AC. My 190XT has a clutch issue as well, so I have bigger problems. If you solve it, be sure and post back.
------------- 80 7010, 80 7020. 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
Posted By: tbran
Date Posted: 17 Jun 2019 at 9:11am
Interestingly enuff, the first 190's drove the compressor off the belt drive pulley - just have to keep the foot off the clutch :-)
------------- When told "it's not the money,it's the principle", remember, it's always the money..
Posted By: Joe(TX)
Date Posted: 17 Jun 2019 at 10:28am
My uncle put an automotive under dash unit in his Gleaner. I had planed to do the same in a 190XT but ended up buying a 200 with air. I planned on using a 200 compressor mount.
------------- 1970 190XT, 1973 200, 1962 D-19 Diesel, 1979 7010, 1957 WD45, 1950 WD, 1961 D17, Speed Patrol, D14, All crop 66 big bin, 180 diesel, 1970 170 diesel, FP80 forklift. Gleaner A
Posted By: CalvikJnso
Date Posted: 02 Jun 2021 at 9:13am
Air conditioning in the car makes driving more comfortable. Too low or too high a temperature does not give pleasure to travel. I hate driving when I can be boiled alive in my own car. I tried to install an air conditioner in the service, but my local specialists refused to do this work, without even explaining the reason. I have a friend who advised me to contact an air conditioning service company. And it really helped, very polite and accessible company https://www.airconservicingsingapore.com/" rel="nofollow - https://www.airconservicingsingapore.com/ explained how to solve my problem. Try to consult with specialists regarding your problem, and it is absolutely free.
Posted By: DaveH
Date Posted: 02 Jun 2021 at 1:33pm
Thanks for everyone's feedback. Much appreciated.
