CA Brake Rod Removal
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=154066
Printed Date: 01 May 2024 at 3:43pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: CA Brake Rod Removal
Posted By: Ted J
Subject: CA Brake Rod Removal
Date Posted: 17 Sep 2018 at 11:19am
and Install
My brake rods were put on the wrong sides. In trying to get the adjustable one off the right side I broke it. I have a new one that I picked up at Hutch an want to put it on the left side where it belongs. My problem? I'm glad you asked!
What is the easiest way to get them on and off without tearing everything apart.
Is it easiest to take these off? 2 70225240 1 SUPPORT ASY., guard, R.H. 6 70225238 1 SUPPORT ASY., guard, L.H.
Thanks!
------------- "Allis-Express" 19?? WC / 1941 C / 1952 CA / 1956 WD45 / 1957 WD45 / 1958 D-17
Posted By: Kenny L.
Date Posted: 17 Sep 2018 at 4:28pm
Posted By: Gerald J.
Date Posted: 17 Sep 2018 at 6:43pm
The shop manual might help. http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf" rel="nofollow - http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Posted By: pumpkinman
Date Posted: 18 Sep 2018 at 7:57pm
looeen adj screw take pin out of pedel end support goose up use two lg, screw drivers priy them apart
Posted By: Ted J
Date Posted: 01 Oct 2018 at 6:33am
pumpkinman wrote:
looeen adj screw take pin out of pedel end support goose up use two lg, screw drivers priy them apart | THANKS Kent!! I used a couple of pry bars and got it done.
Now the next hard part is that the RIGHT side pedal WILL NOT come off. The retaining nut and pointed screw came out really easily, but the pedal is SOLID on the shaft. I've tried heat and pounding to try and get it off, with NO luck. What a PITA!!
Thanks to Alex09(WI) who is sending me a new pedal and I'm going to cut the old one off. Unless somebody knows some kind of a trick to do this?
