CA Change TO Snap Coupler HELP
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=154024
Printed Date: 04 May 2024 at 8:19pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: CA Change TO Snap Coupler HELP
Posted By: Ted J
Subject: CA Change TO Snap Coupler HELP
Date Posted: 16 Sep 2018 at 3:23pm
Hi All, I've got a CA that was a pin hitch and I bought a Snap Coupler setup for it. My problem is the right side according to the AGCO Books, #10 - 70226680 BRACKET ASY., regulating spring sticks out too far. It won't allow the 70232755 BRACKET ASY. R.H. to go in far enough to get the bolt hole to line up. It's about a half inch too short. Anybody have this problem before? The bracket I am talking about is the #11 70232755 BRACKET ASY. R.H. on the AGCO books.
The bracket won't allow the drawbar hanger to go on, it is too wide.
------------- "Allis-Express" 19?? WC / 1941 C / 1952 CA / 1956 WD45 / 1957 WD45 / 1958 D-17
Posted By: Ted J
Date Posted: 17 Sep 2018 at 7:04am
BTT I Can't believe that I'm the only one who has this problem.
Posted By: Dakota Dave
Date Posted: 17 Sep 2018 at 9:06am
I believe it,Snap coupler equipment for a CA is hard to find. I've seen Several CAs switched from snap coupler to pin hitch. With the pin hitch you get to keep the hitch when you put the belly mower on. Best of luck the parts manual dosent show A snap coupler. When I got my CA it had no drawbar I installed a C drawbar till I found a pin hitch one. It's a great mowing tractor but intirely to small for anything else.
Posted By: Tracy Martin TN
Date Posted: 17 Sep 2018 at 9:34am
Ted, I have not done the swap. Can you post a pic or screen shot of what you are running into. I think it can be done for sure. HTH Tracy
------------- No greater gift than healthy grandkids!
Posted By: Ted J
Date Posted: 17 Sep 2018 at 10:17am
You can see the hole where the bolt is supposed to go. The blue line shows where some of the material will have to come off to move the bracket in far enough to accommodate the bolt. The front bolt is in but the back bolt won't go... the rear of the tractor is to the left. I don't know if this helps or not? It's the only photo that shows anything.
Date Posted: 17 Sep 2018 at 10:41am
Ted, does the parts manual call for a different part number on that bracket, for the pin hitch versus SC hitch. If so, if yours bolts up parallel to other brackey and correct width, I would make a new ear, cut off old one, and weld new one on. I think I ran into something similar on a D10 swap on same bracket IIRR. HTH Tracy
Posted By: Ted J
Date Posted: 17 Sep 2018 at 11:26am
Tracy, tThe AGCO Parts book shows them as being the same number, but the pics show that they are entirely different. I'll have to maybe look around and see if I can find the later one. The snap coupler came out in 54 so the preceding two years were pin hitch.
Posted By: CTuckerNWIL
Date Posted: 17 Sep 2018 at 3:46pm
Unless I'm missing something, I believe a 4 inch angle grinder would make the bracket fit.
------------- http://www.ae-ta.com" rel="nofollow - http://www.ae-ta.com Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
Posted By: Ted J
Date Posted: 01 Oct 2018 at 6:22am
UPDATE:
I have to thank Alex09(WI) for the new one. It fit perfectly!!
There is about 3/8" difference in the width of these two pieces, even though they have the same parts number, 70226680. I don't know, if a person had a GOOD bandsaw, if they could have cut it off? I'd be worried about the pin that the right hand bracket assy goes onto would be solid enough? You'd have to take the pin out of each and measure how far it goes in.
It's a LOT easier to have the correct piece, believe me!
Posted By: Alex09(WI)
Date Posted: 01 Oct 2018 at 11:53pm
Thanks Ted! This was certainly a learning experience!
------------- www.awtractor.com A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY
