Print Page | Close Window
Allis C front Steering Gear Removal Help
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=142344
Printed Date: 04 Apr 2026 at 8:31am
Topic: Allis C front Steering Gear Removal Help
Posted By: easygoin4
Subject: Allis C front Steering Gear Removal Help
Date Posted: 11 Sep 2017 at 7:00am
I have a 1944 C Narrow front, found that the slop is in the horizontal shaft bushings for the steering.
I have dropped the pedistal, all wheel bearings and gears are ok.
Removed the set bolt on the side of the sector gear up in the front, below the radiator.
The shaft is wleded to the short steering arm, as shown in my diagrams, and gear should slide off the shaft.
Problem is- I cant get the gear off to replace the bushings.
Any tips on this?
Not much room to get up in there thru large hole in the bottom where the pedistal mounts.
Thanks in advance..
Posted By: CTuckerNWIL
Date Posted: 11 Sep 2017 at 7:38pm
I was just looking at the AGCO parts book. It shows 3 different short shafts. 2 of them have a nut to lock the gear on. The other one must be pressed on, because there is nothing threaded and no kind of retainer on the "inside" end of that stub.
Date Posted: 13 Sep 2017 at 2:10pm
I have that diagram also-
My shaft has the set screw and the nut, which I have removed both and think it sould come right off.
Been tapping on shaft at the bottom - trying to get it off.
Also tried prying wiith bar from inside.
It's not moving...
I have to clean more grease off then may try some heat on gear.
Sure did not make it easy to get in there.
Thanks
Date Posted: 06 Oct 2017 at 12:33pm
Well been working on this for couple weeks now, applied heat from torch few times, put a porta-power on it.. NOTHING
Had an idea which I think I will try this weekend..
Take off grill and drill a 1/2" - 3/4" dia. hole thru steel frame directly across from the steering shaft and use a steel rod to try and get the shaft off the gear by hitting the steel rod.
My idea of cutting the shaft wont work- shaft too long once cut still not enough room to get gear and remaining shaft out of hole.
Hope this post helps someone else...
Posted By: Dakota Dave
Date Posted: 06 Oct 2017 at 3:46pm
Once you have the grill off unbolt the radiator take off the four studs holding it to the engine and you can have it on your bench to work on. I put mine in the press used a bar and hunk of metal for a teeter totter offset and press it out. I have used a large pickle fork and big hammer to remove the bear on one a long time ago. But I had to dot it on the bench there's just no way to get a stubborn one off still on the tractor. The CA I took apart for parts came out real easy. I just took the nut off wacked it once slid the gear out and pulled the shaft. I think I still have a extra housing laying on the shelf if you still can't get it apart
Date Posted: 16 Oct 2017 at 8:12am
Finally got gear off by drilling a 3/4" hole in casing opposite the shaft and pounding out shaft.
Question- what are the 3 holes in the casing that appear to be threaded and the 3 dimples in the shaft for.  It is not indicated on any parts diagram.  Almost like it should have a ball and spring to fall in detent to hold shaft steady- but for steering?
Anyone seen this..
Thanks
http://s382.photobucket.com/user/easygoin4/media/Allis%20Chalmers%20C/steering%20housing.jpg.html" rel="nofollow">
http://s382.photobucket.com/user/easygoin4/media/Allis%20Chalmers%20C/steering%20gear%20and%20shaft.jpg.html" rel="nofollow">
Date Posted: 16 Oct 2017 at 9:10pm
Pictures didn't work.
Posted By: Dick L
Date Posted: 16 Oct 2017 at 9:45pm
Date Posted: 17 Oct 2017 at 11:37am
Pictures were on there the first day..
I used Photobucket and never had a problem- now it appears they want $$ to join so that my pictures will show up...
What sites are you using to post pictures..
Thanks
Posted By: Dick L
Date Posted: 17 Oct 2017 at 11:48am
I use http://www.fotki.com" rel="nofollow - www.fotki.com You can get it free but I pay 5 years at a time to make sure I can not loose my thousands of pictures.
Posted By: Dick L
Date Posted: 17 Oct 2017 at 5:45pm
