D15 will not crank over
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=141951
Printed Date: 15 Sep 2025 at 5:08am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: D15 will not crank over
Posted By: D15Kevin
Subject: D15 will not crank over
Date Posted: 29 Aug 2017 at 10:01pm
Hi all, Just joined and first post on this forum. I have a very clean Series II D15 that I bought from the original family maybe 10 years ago when they were selling their farm. The Grandpa bought it new and was told it was delivered right from the factory on a railcar and since factory was only 20 miles away guess I can believe it. I actually live 1 block from the factory in West Allis myself and can see what's left of it from my backyard. I took tractor up to our cottage in northern Wisconsin and have had it parked in a storage container and occasionally started it and drove it around but it was kind of a hassle getting it in and out so it's just been stored basically. Well it's been sitting for a while now but I have a large pole barn now to keep it in and want to actually use it so I tried to start it last fall and move it. First off the fuel bowl was leaking like crazy and it wouldn't fire so I just left it sit until this last week when I had some time to play with it. I had to mess with points last time I started it so I bought a new fuel bowl, plugs, wires, point and cap and rotor to install. Was just up last week so I installed fuel bowl and new gas line first and then tried to fire it up. All it did was clunk when I hit starter button. Double checked battery in an old car and it cranked it over no problem. Cleaned terminals, same thing. Took covers off and tried tapping on starter to see if it was maybe stuck. Tried to see if engine would turn over grabbing fan and turning and didn't seem to budge. Tried putting it in high gear and rocking tires with no luck. Almost seemed like the engine is stuck but it cranked over no problem last fall and it is in a weather proof container and I did have stack covered too. Anyway eventually just wanted to get it out of container and into garage so I could actually work on it so I jacked up bucket and chained it up and pulled it out with truck and rolled into garage. Moved easily in neutral too. Once in garage figured out how to remove starter and just pulled it out a couple inches but not totally out of housing. Tried starter button with it still connected and it seemed to spin ok. With starter pulled back a bit I tried to spin engine by fan again and now it turned easily like an eighth of a turn and then seemed to lock up again. I thought maybe starter was not releasing originally and binding it up but now it seems locked again. That was about all the time I had so just left it like that until I get up next time. Anyone have any ideas what's going on here. Is there something that could be locking this up? I'd really appreciate any advise as I've never really worked on one of these.
Thanks, Kevin
------------- In the shadow of the West Allis tractor plant
Posted By: rustydollar
Date Posted: 29 Aug 2017 at 11:18pm
It's possible there was moisture in the oil that has over time deposited a thin layer of rust on the cylinder walls underneath the pistons.
Another thought maybe a stuck valve, but I would think the starter would have enough power to overcome a stuck valve then bend the push rod.
I'm placing my bet on rusted cylinders underneath the pistons.
Posted By: lentsch
Date Posted: 30 Aug 2017 at 12:29am
I would remove the spark plugs and then try to turn it over by hand.
------------- WD,D15,190XT,7000,8010x2,7060,8070
Posted By: D15Kevin
Date Posted: 30 Aug 2017 at 12:52am
Should of mentioned I did remove plugs and also there was no sign of moisture in crankcase from what I could tell anyway. Like I said after I pulled starter back a bit I could easily turn engine for maybe an eighth turn and then it seemed to lock again. I should of totally removed starter to check gear on bendix to make sure it was intact but didn't have time. I was wondering if that could of broke and somehow jammed into flywheel because when I pulled it back it did turn easily for a bit.
Kevin
Posted By: Gary
Date Posted: 30 Aug 2017 at 5:43am
First thing I would check is the Anchor Stud and Nut that secures the Starter in place. This stud also serves as the negative grounding spot for the battery.
Gary
Posted By: DougS
Date Posted: 30 Aug 2017 at 5:52am
Remove the plugs and shoot some oil into the cylinders. Was the exhaust covered after you last started the engine? I suspect that moisture got into one or more cylinder and formed a bit of rust.
Posted By: jaybmiller
Date Posted: 30 Aug 2017 at 5:59am
What I would do is.. 1) remover starter 2) emove all plugs 3) engage PTO 4) put pipe wrench on PTO shaft and try to turn over engine
do NOT force it but it should go round and round..
if not, then mix up some acetone and diesel fuel 50:50, pour into all cylinders, go to bed... next day, try #4 again. if it moves say 1/4 turn CW, turn it back CCW 1/2 turn OR until 'snug' again. add more ace/die mix, walk away another day. repeat this test/turn/add/walk away It took me 2 weeks of this routine but 'Troy' freed up after sitting 25+ years ! Patience, oil and more patience. the 'Holy Trinity' of getting old tractors to run again.
Once you can spin the engine smoothly using the PTO method, DISENGANGE THE PTO ! THEN put the starter back in, it should spin the engine. After that, add fresh gas, pull choke and she should start fine..... ..if not report back, we're here to help. Better to ask BEFORE you bust 'something'. Jay
------------- 3 D-14s,A-C forklift, B-112 Kubota BX23S lil' TOOT( The Other Orange Tractor)
Posted By: corbinstein
Date Posted: 30 Aug 2017 at 6:26am
Did the same thing to a stuck B. Worked fine. Tractor still runs fine.
Posted By: Hubert (Ga)engine7
Date Posted: 30 Aug 2017 at 9:04am
X2 on Jay's post. Another mixture to use is atf/acetone 50/50. After you get it freed up change the oil and filter. You may also need a new set of points and condenser, make sure you get a good set and not some of the imported junk that is out there. Steve in NJ has the quality sets and is one of the advertisers that supports this Forum. He is also the guru on anything electrical for these old tractors. http://www.bb-customcircuits.com/" rel="nofollow - www.bb-customcircuits.com/
------------- Just an old country boy saved by the grace of God.
Posted By: D15Kevin
Date Posted: 30 Aug 2017 at 11:35am
Guaranteed no water got in besides moisture in air, it was covered and exhaust was covered. I've worked on other old stuff like Model T Fords and it just doesn't seem like a stuck engine because like I said when I pulled starter back it did easily turn some by hand before it jammed up again. That's why I was wondering if something possibly broke and is jamming it. I had my truck once seize up when I tried to start it out of the blue and it turned out to be the distributor gear broke and was jamming it. That's what I was wondering about on this if something like that could of happened. Next time I go up I will definitely try the PTO pipe wrench idea and will squirt some mixture into cylinders regardless. It's been a long time since I actually used this besides starting it once in a while. I basically took it up and put it away and only really drove it once or twice right after. Which is the lever that engages the PTO?
Thanks, Kevin
Posted By: Tracy Martin TN
Date Posted: 30 Aug 2017 at 1:24pm
Probably has sweated stuck. It happens when the temp changes under tarps, in containers and some buildings. HTH Tracy
------------- No greater gift than healthy grandkids!
Posted By: TimNearFortWorth
Date Posted: 30 Aug 2017 at 1:28pm
If tractor was running but sat protected for a number of months you may not have enough of a battery to spin it well enough. Even though the battery spun something else over, you have a 160 that I just went through the same thing with. Sat for six months in my shop since bringing it home and I knew the battery from the PO was just good enough to jump it off for loading. Put in on a charger for 6 hours, rigged up my portable gas tank with fresh gas and could hear the starter trying but no-go. Mine had a alternator conversion so heavy jumper cables from my 6.0 HD for 5-6 minutes and she really spun but still had to work the gas to her before she finally fired. May want to try a better/bigger bat, plus fresh gas to get her to pop.
Date Posted: 30 Aug 2017 at 3:14pm
PTO lever is on 'bell housing', lower left usually oil drips from there....sigh... It's a flat metal bar, bent at top for the 'handle' portion of the lever. Close to clutch pedal stuff....
I wouldn't let starter turn it over until YOU can do it by hand ! You can feel a 'stuck something or other' while the starter can't and will bend or break that 'somthing' before you can say 'aw shoot'....
Jay
Date Posted: 30 Aug 2017 at 3:31pm
X2 on that, infrequent oil changes.
The recent Onan engine I purchased had milky colored oil indicating moisture, after running the engine to warm up temperature removed the filler cap to let the moisture evaporate. Third time oil clean as a whistle.
If the OP were to check the breather cap, probably see indications of white sludge.
Posted By: DiyDave
Date Posted: 30 Aug 2017 at 6:34pm
Most likely sweat stuck, IMHO, but mice love to nest in these bell housings, for some unknown reason. you might wanna check for foreign objects, in the bottom of the bh, as well as the stuff other posters have said. Usually, a big wrench on the pto, or rocking the rear wheels in 4th gear will unstick stuck rings. I have seen the best wrench to use, its a piece of female drive shaft, welded to a 4'long winch bar, even has the knurling, on the bar, to keep yer hands from slidin off...
Posted By: Gerald J.
Date Posted: 30 Aug 2017 at 6:37pm
Any time you force a stuck engine over, the piston rods going up can be bent sideways which adds to the piston and rod bearing friction, and the bent rod often breaks poking parts through the crankcase wall or engine block wall.
Gerald J.
Posted By: Herb(GA)
Date Posted: 30 Aug 2017 at 10:07pm
Kevin, Welcome to the best antique tractor forum. Series II, D15; that is a good machine. Herb(GA)
Posted By: DiyDave
Date Posted: 31 Aug 2017 at 4:55am
Gerald J.
I didn't say force anything over. perhaps I shoulda said, gently rock back and forth...
Posted By: DougS
Date Posted: 31 Aug 2017 at 5:12am
Covered exhaust doesn't mean water won't leak in. I've had water leak in past the end seams on mufflers on my remote generators. I believe it can leak past where the muffler joins the manifold too. It almost sounds as if there's water in a cylinder and it waterlocks when the piston moves up on the compression stroke.
Posted By: VTdirtguy
Date Posted: 31 Aug 2017 at 6:52am
DougS wrote:
Covered exhaust doesn't mean water won't leak in. I've had water leak in past the end seams on mufflers on my remote generators. I believe it can leak past where the muffler joins the manifold too. It almost sounds as if there's water in a cylinder and it waterlocks when the piston moves up on the compression stroke. |
He said he took all of the plugs out though, so hydraulic lock isn't a possibility.
It very well could be a valve or tappet stuck, not allowing camshaft to turn. Bellhousing junk is another likely possibility. I wouldn't think stuck rings as it does move some. Valve train is most likely culprit.
------------- Grampa's old C got a whole new lease on life.
Posted By: D15Kevin
Date Posted: 31 Aug 2017 at 9:15pm
Thanks all for the advise. I'll probably be heading up later next week and will check it out closer then and also soak the cylinders down and try the wrench on the PTO trick. I will also pull the starter all the way out and check out the gear. Is there any kind of inspection cover to get a look at clutch and flywheel to see if anything is in there? I did think of the hydro lock thing and that's why I pulled plugs out originally as last fall I was cranking it over but gas was leaking all over. Thought it might of flooded in engine as it wouldn't fire and I just let it sit after that. Don't think any of that happened as oil looked and smelled fine and plugs were dry as can be.
Anyway here are a couple pictures. First one is probably 10 years ago when we hauled it up. Picture is in the alley behind my house in West Allis. In the background is Motor casting Co. and directly behind that is the old Allis Chalmers tractor plant which you can't see in picture.
Second picture was last week when I pulled tractor out and pulled in garage.
Posted By: Gary
Date Posted: 01 Sep 2017 at 5:43am
Put the tractor transmission in neutral, engage the PTO ( lever forward )
then you can put a Pipe Wrench on the rear PTO shaft and see if you can turn the engine over.
Gary
Posted By: D15Kevin
Date Posted: 12 Sep 2017 at 9:56pm
DiyDave wrote:
Most likely sweat stuck, IMHO, but mice love to nest in these bell housings, for some unknown reason. you might wanna check for foreign objects, in the bottom of the bh, as well as the stuff other posters have said. Usually, a big wrench on the pto, or rocking the rear wheels in 4th gear will unstick stuck rings. I have seen the best wrench to use, its a piece of female drive shaft, welded to a 4'long winch bar, even has the knurling, on the bar, to keep yer hands from slidin off... |
DiyDave was correct!
Pulled starter out and it was packed in there with mouse nest so I went
underneath and pulled round access cover off bottom of bellhousing and
it was packed SOLID with mouse nest. I had to jam a screwdriver in just
to start breaking nest loose. After a couple hours of pulling stuff out,
blowing through top and from underneath with air nozzle seemed to get
most of it out. It did take a big pipe wrench on PTO to break it loose.
After just pulling out what I could at first and putting wrench on it I
could start to turn it a little and then it would lock but after a lot
of back and forth with wrench and cleaning got it to turn pretty easy.
Looks very clean now.
Still couldn't get it running though. ran
out of time to work on it. Got it to pop a few times anyway so just took
carb off to bring home and rebuild for next time. should hopefully be
good to go then.
 Thanks to all for the advise! Probably more questions to follow.
Kevin
Posted By: Brian Jasper co. Ia
Date Posted: 13 Sep 2017 at 12:52pm
I almost went right to the end of this post to say mouse nest, but I see you found it. I hate mice! Mice!
------------- "Any man who thinks he can be happy and prosperous by letting the government take care of him better take a closer look at the American Indian." Henry Ford
Posted By: Bweston
Date Posted: 17 Mar 2022 at 7:25pm
I just started working on my dads d15 ac not a 100 percent on year I’m thinking early 60’s it has been converted to a 12 volt battery system by previous owner the positive is still acted as the ground the ground wire is connected to the starter.
I just bought a brand new battery for it ( the tractor has been sitting for a few years ) and when I turned on the key and clicked the starter all it did was click more of a clunk it didn’t try to spin just sounded like a dead battery but it’s brand new , I can turn the fan blade freely I’m not thinking it’s locked up by any means, I also took the plugs out and they didn’t look terrible. I’m just hoping for a step in the right direction/ someone that has had the same issue before we put a bunch of money into it and it be somthing semi simple thanks in advance.
Posted By: steve(ill)
Date Posted: 17 Mar 2022 at 7:35pm
Leave the plugs out. You turned the FAN, did the motor pulleys turn ? .... 90% of the time a NO CRANK is due to bad battery cables, or bad starter solenoid... Take the cables off and clean the ends with wire brush to CLEAN METAL.. Where the cables connect, make sure the terminals are all bright and shinny also..
Im not sure i understand you cable description 100%.... If you have a POSITIVE GROUND then the POSITIVE terminal on the battery is ground to the frame ( clean and install new ground bolt).... The NEGATIVE terminal of the battery goes to the starter solenoid, and the other side of the solenoid goes to the starter terminal.... The small wire on the SOLENOID comes from the key and energizes the solenoid so that internal the TWO BIG lugs are connected.
------------- Like them all, but love the "B"s.
Date Posted: 17 Mar 2022 at 7:44pm
Your battery / starter / solenoid wires should look something like this... I assume you have a generator and not an alternator... that is not important right now..
( "the negative battery wire goes to the starter " ) .. do you actually have a SOLENOID that is turned on by the KEY. or do you turn the key to ON, and then push a starter rod >
Posted By: Bweston
Date Posted: 17 Mar 2022 at 8:38pm
To turn the tractor on it’s actually on a toggle switch for power then you have to press a push button
Date Posted: 17 Mar 2022 at 10:28pm
OK... the push button takes the place of the ignition switch "start" position... But you still need a solenoid, maybe mounted to the starter, that has the BIG BATTERY wire connected to it ?
Again... ALL of the battery cables need to be clean, shinny, and good bolts on the ground cables...... The starter also is GROUNDED to the bell housing/ motor block.. The mounting face of the starter and the bell housing it bolts to need to be CLEAN
Posted By: DrAllis
Date Posted: 18 Mar 2022 at 6:38am
ALL D-15's were always 12 volts !!! So, are you sure it isn't a D-14 ?? because the early ones were 6 volts. This makes a difference on starter parts as they are NOT the same.
Date Posted: 18 Mar 2022 at 6:49am
LOVE the 'mouse house' pictures !!! Reminds me of 'Troy', my 1st D-14.. Had to split tractor to clean it all out, also needed new clutch assy..mouse piss is horrible stuff.
quick, way to tell if 6 or 12 volt...starter casing will have a 'band' around the brushes IF 6 volt, NO band means 12 volt. Also you can count the teeth on the starter. They are NOT the same ! which means different ringgear as well . Found that out one day.......
Posted By: Bweston
Date Posted: 18 Mar 2022 at 7:02am
As far as I know it’s a d15 that was the manual that my dad got with the tractor when he bought it I’m gonna try to clean everything up this weekend thank you for a step in the right direction I just didn’t want to drop a bunch of money into it if it’s somthing like this that fixes it
Posted By: CTuckerNWIL
Date Posted: 18 Mar 2022 at 4:06pm
I just bought a brand new battery for it ( the tractor has been sitting for a few years ) and when I turned on the key and clicked the starter all it did was click more of a clunk it didn’t try to spin just sounded like a dead battery but it’s brand new , I can turn the fan blade freely I’m not thinking it’s locked up by any means, I also took the plugs out and they didn’t look terrible. I’m just hoping for a step in the right direction/ someone that has had the same issue before we put a bunch of money into it and it be somthing semi simple thanks in advance. |
If it's wired as Positive ground and the Ground wire is hooked to the starter, there is no way to get battery power to the starter. On a Positive ground system, the Negative cable has to hook to the starter and the Positive is grounded IE Positive Ground.
------------- http://www.ae-ta.com" rel="nofollow - http://www.ae-ta.com Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
