7060 progress update
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=123632
Printed Date: 28 Dec 2025 at 6:18pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 7060 progress update
Posted By: Michael V (NM)
Subject: 7060 progress update
Date Posted: 21 May 2016 at 9:58pm
I got a new alternator from shoup, itsa delco replacement.$173.00, so all is good with the electric things I'm gonna keep that darned Niehoff, I know theres got to be gold in it somewhere....
also got new heater hoses with a shut off at the engine
 my helper Marley as you can see new foam for the radiator, got a fresh oil change(had to get the bypass filter from AGCO, its been discontinued every where else I looked)new air filters
oh yea, I got the P/D valve sealed up, just did the outside seals and the O-rings between the valve and trans housing, nice now, it don't leak
worked on the AC yesterday and today, new expansion valve and R/D and one questionable hose replaced. drew a vacume kinda late last night, shut all down, it was still holding same this morning.more vacume today, got AC charged and so far its working good all new foam under the cab roof and cleaned up the cores up there new music box in the cab, new floormat,I have a cab kit, guess that will be next, yea, prolly shoulda done the floor mat last tho
Posted By: SHAMELESS
Date Posted: 21 May 2016 at 10:44pm
did you put any sealer or rubber on the cab roof bolts? if not, you'll gits water in there.
Date Posted: 21 May 2016 at 10:53pm
yes they got new 'rubbers'
Posted By: DIESEL
Date Posted: 21 May 2016 at 11:41pm
What did you put in for a radio? I've got my roof off getting painted and fixing ac and I'm trying to decide what to order for a radio.
Date Posted: 22 May 2016 at 8:41am
I found a new unused shaft radio/cassette with 5" speakers on ebay ,itsa sparkomatic, works ok but not as good as a pioneer of 80's vintage. I still had to make some adjustments to get it to fit, speaker holes really not quite big enough for the 5", original AM/FM hole had to be modified... it really sucks that ya hafta take the cab roof off to work on the radio I also lubed the heater control cable and valve, it works really good now, blew all the dirt and crap out of the cores, Don't forget to clean/blow out the AC drain lines
Posted By: nickia
Date Posted: 22 May 2016 at 9:14am
where did you get your heater shut off valve at?
Posted By: darrel in ND
Date Posted: 22 May 2016 at 9:21am
I think you are going to like that tractor. What are your intended uses for it? Darrel
Posted By: hillmonkey
Date Posted: 22 May 2016 at 9:53am
NICE,always cheap insurance to do a "cat scan" on the front axle before the field test.
Posted By: DIESEL
Date Posted: 22 May 2016 at 12:18pm
That's what I was afraid of, if I have to cut out the counsel I'll probably just order a new stereo out of crutchfield. What did you use for roof insulation?
Posted By: Adam Stratton
Date Posted: 22 May 2016 at 3:40pm
What sort of radio are you after? I have some original am only Allis Chalmers marked radios, also have some speakers that came with them. I was thinking of putting them on ebay, but I would probably make a deal if anyone was interested.
Date Posted: 22 May 2016 at 10:25pm
Nick, I got the shut off valve at local parts store, itsa just a generic heater shut off valve.. a ball valve would work also, and be nice, only 1/4 turn off/on,, but parts store didn't have one when I was there, ya can go with 1/2 or 3/8, jus get the barbs for whatever size hose, ya could hard mount the ball valve on one side..
hill, yea Marley scans lots stuff, helped me put in the cab kit today, sorry, no pics,, but sure looks nice inside now
Darrel, its hooked to a 4212 sunflower 13 shank coulter chisel now, workin it out pretty good. and whatever else I can think of to hook it up to, Great Plains grain drill, 7000 JD planter.... but eventually I'm hopin it to be my baling tractor with the NH 2000 3x4 baler...all ya'll that changed PTO to 2 speed,, well, I want to go the other way with the 1 3/4" 1000.. I gots lot of other tractors with 540,, 8010 is dual speed..
Diesel, I found some 1" foam at wally world, I would think Hobby Lobby or other such places would have foam
I got the duals mounted back on( those 20.8's really set her up nice) and cab kit installed today, tried out on the chisel,,I LIKE MY ORANGE TRACTOR,,got couple more oil leaks to fix, but that's work in progress...maybe I can get ya'll some pictures of it workin in a day or so
Posted By: mason97x
Date Posted: 16 May 2017 at 11:43am
Michael, Do you happen to have any pictures of the back of your compressor? I was curious as to how you eliminated the service valve manifold on the back of the compressor and couldn't zoom close enough to see the picture.
Thanks
Posted By: lowell66dart
Date Posted: 16 May 2017 at 12:34pm
Nice work. I just made a deal this morning to trade my 200.for an early 7060 PD so I will be following your progress.
------------- AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Date Posted: 16 May 2017 at 5:03pm
I'll try an get y'all some more pictures Lowell, I really haven't gone much else, does have a new seat since this was put up last year ....oh yes,, almost forgot,, it got a new set of injectors also
