Allis Chalmers 7020?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=123326
Printed Date: 10 Aug 2025 at 1:40pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Allis Chalmers 7020?
Posted By: keith wd
Subject: Allis Chalmers 7020?
Date Posted: 14 May 2016 at 8:06am
Wandering if anyone has fixed a allis 7020 transmission with a powershift and how hard is it to fix it.
Posted By: nevans
Date Posted: 14 May 2016 at 9:09am
we have rebuilt p.s. shift trans for all the 7000 and 8000 series tractors they aren't to hard to work on but finding good parts is getting harder Niel
Posted By: critter
Date Posted: 14 May 2016 at 10:54am
We did one 2 winters ago, it's not to bad if you have a overhead hoist or forklift and a service manual. Had to make a couple special tools, it would definitely go faster the second time, and if you get stuck ask on here, lots of people will help.
Posted By: Orange Blood
Date Posted: 14 May 2016 at 4:03pm
Invest in the ALLIS service manual still available from AGCO, almost all soft parts still available from AGCO, not cheap, and there are some stashes of hard parts to be had.
Depending on what is wrong with yours, it can be a few grand, to well into the $5 to 7K probably not worth it, I know some guys who you can get rebuilt for less.
------------- Still in use: HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7
Posted By: critter
Date Posted: 14 May 2016 at 4:29pm
What is wrong with yours?
Posted By: keith wd
Date Posted: 15 May 2016 at 8:36am
The tractor will run fine for an hour and then it will just stop and not move
Posted By: Lynn Marshall
Date Posted: 15 May 2016 at 9:30am
More information is needed on this problem before an accurate diagnosis can be given. This could be nothing more than an oil supply problem.
Date Posted: 15 May 2016 at 1:20pm
Well I wouldn't run it anymore.
As Lynn said, we need more information.
It is time to pull oil pressures on the pump first, then clutch packs, and find out where the problem is. At this point the damage may be done, even if it is the pump. It takes very little continued slipping of the clutch pack to burn one out.
Posted By: keith wd
Date Posted: 15 May 2016 at 3:40pm
That is the worst part is that the oil level is good just don't know what else to say is happening.
Date Posted: 15 May 2016 at 5:26pm
Well if you were considering doing the repair yourself, you are probably more than skilled enough to take some pressure readings???
Also just to be absolutely sure, does the PTO turn when the tractor won't move, when you are trying to move? (IN gear, clutch out)
Does the problem exist in every gear, or just a couple, or maybe only one?
Posted By: keith wd
Date Posted: 15 May 2016 at 5:48pm
Happens. In every gear PTO will turn
Date Posted: 15 May 2016 at 6:05pm
What does the engine do when it won't move, does it pull down, or run like it is unloaded? By pull down, I mean, like it is working hard, not just a bump in RPM downward.
When it won't move, is it pulling an implement, like a disk in the ground, or just itself across the yard?
Posted By: keith wd
Date Posted: 15 May 2016 at 8:09pm
It runs like it should and does not run hard in the rpms and that it is running it around the yard
Posted By: MACK
Date Posted: 15 May 2016 at 9:47pm
Do you feel a solid détente when you shift through the gears? Have you had it on a good pull to see if it will pull a good load before it stops? What do you do to make it move again?
Where are you checking the oil? Does the 1800 light on dash work? If so does it come on when it stops? MACK
Posted By: keith wd
Date Posted: 16 May 2016 at 9:17am
don`t own anything big enough to make it work hard enough will pull anything and that when it happens just let it sit for a while basically when the tractor has cooled down and nothing is warm it will move again then and yeah have been checking everything that i can got the book out and look to see if looking in the rit places and it is.
Posted By: keith wd
Date Posted: 16 May 2016 at 9:19am
keith wd wrote:
don`t own anything big enough to make it work hard enough will pull anything and that when it happens just let it sit for a while basically when the tractor has cooled down and nothing is warm it will move again then and yeah have been checking everything that i can got the book out and look to see if looking in the rit places and it is. | and that it will just go through the gears and not make a sound
Posted By: MACK
Date Posted: 16 May 2016 at 10:16pm
I think it is loooow on oil. Pull the dip stick under the left side of the seat. Not the first one I've saw do the same thing. Low on oil.
MACK
Posted By: tbran
Date Posted: 17 May 2016 at 11:28am
as in the advice above- first do the checks. Get the service man and locate the check plugs, air pressure each clutch pack and LISTEN for pack application and for leakage in all 6 - IF that passes the you have either an oil supply or pressure issue... could be anything from cable adjustment, gearoter pump relief valve modulator etc...
------------- When told "it's not the money,it's the principle", remember, it's always the money..
Posted By: keith wd
Date Posted: 18 May 2016 at 8:45am
well found the problem there was a plug on the rear end that i had never known about the worst part is that i had just bought the tractor less then a year ago then we started to planting corn and just put it in the barn and thought it would be a good idea to start on it with how much rain we got and that the tractor was a mess and that the guy before me never took care of anything and that there was mud and crap all over and missed the plug and that it was very low on oil to where it took a lot of oil so now it moves and run fine. Thanks to everyone who had tried to point out things for me to check.
Date Posted: 18 May 2016 at 12:42pm
If I had a beard, I would stroke it, so instead I will just scratch my head. This makes no sense whatsoever.
Posted By: scott
Date Posted: 18 May 2016 at 1:11pm
Im betting theres another plug by the first plug thats still covered with mud. Did he find the hi or low level plug?
Posted By: MACK
Date Posted: 18 May 2016 at 10:36pm
I would guess he found the dip stick under the seat. Low oil in rear end would not keep it from moving. MACK
Posted By: SteveM C/IL
Date Posted: 18 May 2016 at 11:51pm
MACK wrote:
I think it is loooow on oil. Pull the dip stick under the left side of the seat. Not the first one I've saw do the same thing. Low on oil. MACK
I kinda smile when this happens,almost like someone knows what he's talking about.... LOL LOL
Date Posted: 19 May 2016 at 6:03am
Kinda my thoughts exactly Mack.
Credit to you for pushing this point, I guess I just believed the guy when he said the oil was up.
Posted By: Joe(IA)
Date Posted: 19 May 2016 at 6:13am
Bottom line, all of you guys above give excellent advice and thanks for taking the time to really care and help!!! No matter how the end result is accomplished!
