Print Page | Close Window
Off-color question case 2294
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=120340
Printed Date: 19 Dec 2025 at 12:47pm
Topic: Off-color question case 2294
Posted By: AC 426 power
Subject: Off-color question case 2294
Date Posted: 13 Mar 2016 at 9:33pm
Wondering if anyone has any experience with a case 94 series? I've got a Case 2294 12 speed powershift that out of the blue quiet moving, one moment i was mowing hay last summer and have just now got time to fix it, and then I shut it off to put fuel in it and then went to restart and it would simply not move. No surging of the engine when putting in the clutch as with all case powershifts tractors do that I've owned and operated, I had a respectable old time case dealer come out and they got it to move and told me it was a electrical short and that they had replaced the circuit board under the shifting counsel with a new one, however this was not the problem and even after replacing it, they did show me while I was there that it was a electrical problem by using a tool that I am not familiar with that while attached to the rely wire in dash they could shift the gears with it, you could hear the engine surge just like it always does and the tractor would go through the gears normally although not moving you could clearly hear it go into gear like it would do normally, however i was not able to stay with them through the rest of the repair so a couple hours later they called and said it was a electrical wire problem and the tractor was good to go, but a couple weeks after I was going down the road and went to a stop sign and it did the same exact thing when going to take off it would not move. I have switched the relays around inside the dash and this did not help, and all fuses look good, I did find this while digging around myself connected to the 3 speed powershift which has 8 wire's connected to it, and as you tell with the picture it has cracks in it, I was wondering what this is and if it could be my issue as described?[IMG]
Posted By: Auntwayne
Date Posted: 13 Mar 2016 at 10:36pm
     I hope that you have already called them. This is their baby now.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Date Posted: 13 Mar 2016 at 10:48pm
Don't like the sound of that what do you mean exactly?
Posted By: SHAMELESS
Date Posted: 13 Mar 2016 at 11:55pm
I wonder if that's the same problem I have with my 2290? I didn't know they had electrical on the shifting
Date Posted: 13 Mar 2016 at 11:56pm
where do you access that under the console? inside or outside?
Posted By: LB0442
Date Posted: 14 Mar 2016 at 12:17am
Case IH has the parts books online just like AGCO.  At least you can find that part and it will give a good description of it.  It won't help with diagnosis but it does help narrow down what area that relay is used in.   Lon
Date Posted: 14 Mar 2016 at 5:48am
Its under the console and it's what the power shift lever is connected to but I don't believe the 90 series have electric power shift.
Posted By: BPM75
Date Posted: 14 Mar 2016 at 9:08am
90 series were not electrical only the 94 series.
59 D17 gas nf, 66 XT 190, 69 220.
Date Posted: 14 Mar 2016 at 9:25am
dang!
Posted By: Lonn
Date Posted: 14 Mar 2016 at 6:34pm
I believe from this post at another site that it's the power shift switch and it might be expensive
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=case&th=114612" rel="nofollow - http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=case&th=114612
Wink
I am a Russian Bot
Date Posted: 14 Mar 2016 at 6:50pm
Its very expensive $827 to be exact, and no aftermarket option, but I won't cry to much it would sure beat the heck out of having to split the dang thing, as the old saying goes CASE=Can't Afford Something Else
