190 Rear wheel removal ?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=106054
Printed Date: 05 Apr 2026 at 11:47am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 190 Rear wheel removal ?
Posted By: tractorman
Subject: 190 Rear wheel removal ?
Date Posted: 12 May 2015 at 1:51pm
I have to take a rear wheel off my 190. What is the best way to do it, thworst seems to be that big bolted bushing ?
------------- Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Posted By: nevans
Date Posted: 12 May 2015 at 4:05pm
if you mean the cast center then yes the three bolts have to come out and three pusher bolts go in and you push the center off the bushing and then you have to spread the bushing a little to get it to slide off Niel
Posted By: Beirnesy
Date Posted: 12 May 2015 at 7:18pm
This old post may help http://www.allischalmers.com/forum/forum_posts.asp?TID=70295&title=190-hub-removal-bolts" rel="nofollow - http://www.allischalmers.com/forum/forum_posts.asp?TID=70295&title=190-hub-removal-bolts
------------- 1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Posted By: DougG
Date Posted: 12 May 2015 at 7:25pm
Get those pusher bolts super tight- then wack the end of the axle with a 13 lb sledge hammer, that sends vibrations into it all
Date Posted: 12 May 2015 at 8:39pm
where do i get the pusher bolts ?
Posted By: BPM75
Date Posted: 12 May 2015 at 9:37pm
If you don't have them I've heard of some guys having them made at a machine shop. I don't remember the dimensions but I'm sure someone on here will know.
------------- 59 D17 gas nf, 66 XT 190, 69 220.
Posted By: DSeries4
Date Posted: 12 May 2015 at 9:55pm
Can you just remove the rim and leave the wheel center on the axle? That would be a bit easier.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '63 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Date Posted: 13 May 2015 at 8:46am
just talked to my dealer, $80.00 each, it didn't happen, they don't rent or loan anymore. It just couldn't happen they would be the same as theones that green color used ?? Ido have a good machinest, any body have the dimensions?? thanks
Posted By: DSeries4
Date Posted: 13 May 2015 at 8:52am
Never used them, but I heard they are made of VERY hard steel. Might be hard for a machinist to make.
Posted By: DonDittmar
Date Posted: 13 May 2015 at 7:19pm
They have to be hard. I had a machinist buddy make them out of standard dowl rod. Didn't last to long before they bent all to he!!
------------- Experience is a fancy name for past mistakes. "Great moments are born from great opportunity"
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start
Posted By: Toscani NE SD
Date Posted: 13 May 2015 at 7:48pm
my method worked very well,i put the pusher bolts in tight and using just a 3 lb hammer tapped on top of axle,both sides popped without hardly any effort and they had not been moved in 30 years,also did my d21 and they moved easily too,i learned this trick from the local tire company as they happened to have done this on a 7580,no swinging a heavy sledge!
Posted By: Lonn
Date Posted: 13 May 2015 at 8:16pm
Back 15 years ago or so I bought them for something like $3 or $4 each. Talk about a mark up
------------- -- --- .... .- -- -- .- -.. / .-- .- ... / .- / -- ..- .-. -.. . .-. .. -. --. / -.-. .... .. .-.. -.. / .-. .- .--. .. ... - Wink I am a Russian Bot
Posted By: kmorth
Date Posted: 13 May 2015 at 8:30pm
You can get a piece of 1/4 in thick flat in between the cast center and the hub and put a regular bolt in and push off the flat metal. not easy but I have done it several times. takes a pretty good impact gun and get them tight and wack it with a hammer.
Posted By: David (in Mi.)
Date Posted: 14 May 2015 at 7:46am
You talk about good luck, you wont believe this, I was reading this thread 2 days ago and thought I may have to move the wheels on my xt someday, and how will I do that, and In the middle of night or something like that, I said to myself, I have seen those push bolts sometime, somewhere, or am I just remembering using them 50 yrs. ago helping my uncle move wheels when he pulled his xt at the local fair. I am now 66 and 16 to 20 yrs old when this happen. So, first thing yesterday I jump in pickup and go over to my uncle farm, which I now own, bought back 15 yrs. ago and start looking around the old, round pole, tool shed, which has the old corrugated galvanizes steel, and believe it or not, there is next to nothing in this shed except machinery, I found In the corrugation, between the ripples, 4 I tell you xt rear wheel push bolts. I WAS THRILLED TO DEAD !!!!! I thought now, that is some good memory, at my age.
Posted By: DougS
Date Posted: 14 May 2015 at 9:17am
Be careful. I'm very close to your age. Excitement nearly kills me to dead too.
Posted By: Lonn
Date Posted: 14 May 2015 at 11:38am
kmorth wrote:
You can get a piece of 1/4 in thick flat in between the cast center and the hub and put a regular bolt in and push off the flat metal. not easy but I have done it several times. takes a pretty good impact gun and get them tight and wack it with a hammer. | I've done this too but have pushed the plate into the threaded hole once that buggered up the first couple threads. Maybe a hardened plate would work better.
Posted By: Joe(TX)
Date Posted: 15 May 2015 at 8:02am
I made a 3 puller bolts per the image. I actually used a grade 5 although a grade 8 would be better. I tightened the bolts with an impact, an hammered on their heads in an alternating manner.
------------- 1970 190XT, 1973 200, 1962 D-19 Diesel, 1979 7010, 1957 WD45, 1950 WD, 1961 D17, Speed Patrol, D14, All crop 66 big bin, 180 diesel, 1970 170 diesel, FP80 forklift. Gleaner A
Posted By: Ray54
Date Posted: 15 May 2015 at 9:28am
Don't celebrate to much yet David,I have done that .But do you know where put them now that you moved them.
It starts with short term going first. Its what happened yesterday not what happened when you where a teen that goes first.
