pie weights |
Post Reply |
Randy WI
Orange Level Access Joined: 22 Jan 2014 Location: Ogema, WI Points: 752 |
Posted: 16 Sep 2021 at 8:08pm |
what are your thoughts on pie weights just bought 8 of them for our D14 I will try to post a pic tomorrow. Randy
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7935 |
They work - just keep the bolts tight
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4605 |
Easier to add weight a 1/4 at a time verses 1 whole weight if that’s what your asking. Our D15 has them and I have a complete set for my 190XT if I would use my 4 bottom plow or pull the 20 ft disc. The disc requires more weight than just the loaded tires. Otherwise I leave them off for hay season.
Randy WI
Thanks this is the first time i have used steel weights. always tire ballast . have rim gaurd in my new tractor adds about 1000 lb. Randy
AC720Man
My WD has fluid and a wheel weight on each side. The wheel weight requires a second person to install the nuts as I hold it in place. Quite hard on your back. Pie weights are much easier.
Post Reply | |
