Parts |
Chevy4x4 ![]() Bronze Level ![]() Joined: 28 Nov 2019 Location: Iowa Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Dec 2019 at 8:30pm |
Looking for sleeves & pistons for a G230 or G262 engine
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1526 |
thank we used chevy- 250 or 292 pistons' you may haft to check it out for wrist pin size.
DrAllis ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 11155 |
I'm a little confused, as usual. The pistons and sleeves are similar in design between the G-230 and G-262, but they sure aren't the same. If you put the wrong ones in a given short block, the stroke of the crankshaft is different between the two engines...………..
Iam talking Allis engines not Chevy. You can put 262 sleeve in a 230 Block
but you have to bore bottom of block .020 bigger. I am a Ex Allis mechanic on my own. For any one that wants to put a 8.3cummins in a 8000 series Allis all you have to do is get a 7140 IH flywheel and turn Allis rear plate around and re drill holes. put starter on battery side. and a few other things. I have done 3 so far one is going on 15 years ago no troubles makes a tractor out of them. Get a drive disc made and throw the # torque limiter as far as you can |
You can put 262 sleeves in a 230 block if you bore bottom 020 bigger. I really looking for 230 or 262 sleeve & pistons. I will make one or other work if I can find ether one. Some one had a post on here in Wisc. said he had some but I cant find it back. This forum is hard to navigate.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 2469 |
Try searching for stuff in the forum by using Google. Go to Google.com and type in allis chalmers forum and then what you are looking for. I have had much better luck finding things that way.
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Elk River,MN Points: 1172 |
I have some 262 pistons and liners. lselkriver@gmail.com
Pfouts Family Farm ![]() Bronze Level ![]() Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 31 |
I have new pistons and sleeves for G262 and know I have some NOS sleeves for G230. Not sure about NOS pistons for the G230, but I think there are some. I will try to take a look today. pfoutsfamilyfarm@gmail.com
Thank you guys for the comeback All I need is 4 of either set. I will buy how you guys want to sell them. I am trying to overhaul a AC fork lift with a G153 engine. The 230 is the same only a 6 Cly. Can you post how you want to sell. Rings are Available. Thanks again.
Chad (MN) ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: sc minnesota Points: 272 |
I would sell you a non-running G230 engine from a Gleaner....SC Minnesota
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
