Parts
Chevy4x4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy4x4 Quote  Post ReplyReply Direct Link To This Post Topic: Parts
    Posted: 01 Dec 2019 at 8:30pm
Looking for sleeves & pistons for a G230 or G262 engineSmile
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 8:45pm
thank we used chevy- 250 or 292 pistons' you may haft to check it out for wrist pin size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 11:07am
I'm a little confused, as usual. The pistons and sleeves are similar in design between the G-230 and G-262, but they sure aren't the same. If you put the wrong ones in a given short block, the stroke of the crankshaft is different between the two engines...………..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy4x4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 11:58am
Iam talking Allis engines not Chevy.     You can put 262 sleeve in a 230 Block
but you have to bore bottom of block .020 bigger.     I am a Ex Allis mechanic
on my own.    For any one that wants to put a 8.3cummins in a 8000 series Allis
all you have to do is get a 7140 IH flywheel and turn Allis rear plate around and
re drill holes. put starter on battery side. and a few other things. I have
done 3 so far one is going on 15 years ago   no troubles makes a tractor out of them.   Get a drive disc made and throw the # torque limiter as far as you can
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy4x4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 10:01pm
You can put 262 sleeves in a 230 block if you bore bottom 020 bigger.    I really looking for 230 or 262 sleeve & pistons.  I will make one or other work if I can find ether one.  Some one had a post on here in Wisc. said he had some but I cant find it back. This forum is hard to navigate.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 5:53am
Try searching for stuff in the forum by using Google. Go to Google.com and type in allis chalmers forum and then what you are looking for. I have had much better luck finding things that way.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 6:30am
I have some 262 pistons and liners. lselkriver@gmail.com
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 8:58am
I have new pistons and sleeves for G262 and know I have some NOS sleeves for G230. Not sure about NOS pistons for the G230, but I think there are some. I will try to take a look today. pfoutsfamilyfarm@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy4x4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 8:50pm
Thank you guys for the comeback  All I need is 4 of either set. I will buy how you guys want to sell them.  I am trying to overhaul a AC fork lift with a G153 engine. The 230 is the same only a 6 Cly.  Can you post how you want to sell.   Rings  are  Available.     Thanks again.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 8:37am
I would sell you a non-running G230 engine from a Gleaner....SC Minnesota
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
