need electrical advice |
Post Reply |
trace
Silver Level Joined: 01 Aug 2012 Location: N.W. Iowa Points: 499 |
Posted: 08 Jan 2020 at 10:07am |
replacing old wall oven. 240v from house two hots and a neutral, from new oven two hots, neutral and ground. my thinking is that i need a new 4 wire line from panel. have read about hooking ground and neutrals together and attach to box but not recommended. what ya think??? getting an electrician around here about as bad as appt with a medical specialist.
1955 WD-45 WIDE FRONT W/ TRIP
LOADER |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21328 |
I'd probably run new 8/3(red/blk/wht/gnd) from panel to stove just to be safe and 'code compliant'. Ground and neutral ARE connected at panel, supposed to be the only place..but yeesh.. I've seen wht and gnds together in applicances. I 'think' the deal is .IF... the neutral (wht) becomes disconnected, power flows through the ground wire...a bad thing ?? I'm sure some wire puller will chime in soon though....
chaskaduo
Orange Level Joined: 26 Nov 2016 Location: Twin Cities Points: 5203 |
This is a adapter for $76 including shipping, there may be less expensive ones out there.
Dave in PA
Orange Level Joined: 13 Sep 2009 Location: Mars/Wexford PA Points: 2615 |
I am not recommending this, for legal reasons! Look at the instruction with the oven. The 3 wire with ground is the best. BUT some units will show you how to hook up with the older 2 wire with ground as well. The difference is the ground is the ground, the 4th wire is a isolated ground, for the unit chassis. 3 years ago, when I did mine, the book showed how to put a enclosed strap in place to cover all bases on this issue.
trace
they do show with mfg info to hook ground to neutral and ground and delivery guys said that's how they hook em up. wish i could find an electriian up here.
LOADER |
Dave H
Orange Level Joined: 11 Sep 2009 Location: Central IL Points: 3476 |
My drier and electric stove are hooked up as Dave described. As I foggily recall, the delivery guys said that they were not authorized to hook up/wire a three pronger. Well there went another trip to Lowes to buy the cord and I think it had wiring instructions with it. Running new romex and all the pfarting around that goes with it is not in my vocabulary. Sides, how many years did the three wire 220 set ups serve our needs?
trace
the wall oven is hooked up direct in a junction box, no plug. surprised the heck out of me that the delivery people would hook up, big liability these days.
LOADER |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41160 |
Seems I have all 3 wire 50 Amp plugs on welders stove and such - then I also have wires to stove run through conduct EMT so there is my ground back to panel - Same in shop the 50A recepticals are all run in EMT .
Have 2 electric kilns 230 V, 50 A the wife bought for her business , they came with 4 prong cord caps so I left them and replaced the receptacle and used the EMT as the ground |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
jaybmiller
A pro will KNOW but I doubt using 'EMT as the ground' is legal let alone safe.... It'd be interesting to find out though. OK I looked it up and yeesh , it IS considered a ground !!! Man that is scary as WHO tightens up EVERY screw, once a year to ensure a low resistance path to the panel ground ?? I've had bad grounds on riders....a bad or open ground running 240 could be fatal !!
Edited by jaybmiller - 12 Jan 2020 at 8:53am |
trace
finally got electrician lined up to change out our panel and run new 220 lines within the next month. those guys busy round here. lot of em independents that can pick and choose their work.
LOADER |
jaybmiller
up here ,they have to pull permits ( 2 X $$$) and have inspections ( 2 X $$$$$) THAT opens up a huge 'can of worms' since once a permit is pulled WHOLE HOUSE is inspected ! From the meter to the furthest outbuilding that has power from the meter.... Everything that is not up to CURRENT code ,HAS to be replaced ! All those whose house is 100% up to code ,please raise your hands..... hmm... I don't see any..... |
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29233 |
Ground is not Neutral, Neutral carries the return current ground is just that least chance saving grace that the neutral does fail or a stray current invades the supplied device metal structure there is a alternate path. Conduit will carry that. If in any doubt can run a Secondary Ground to hard metal structure at the appliance and do just as well.
My younger brother took over our Dad's lake of the Ozarks vacation house, has a dock with lighting, ALL EMT Conduit with Hard Ground to shore, Lake Ozark city council decided HAD to have a Separate at the bank Hard ground rod, that lasted a year, then required a GFI for the ENTIRE Circuit to the Dock in house box, that as well lasted a year, then a Separate Disconnect at the dock, then a change in that to a Automated GFI control, it goes on and on and on and for all reality any if not all the devices can fail from age, rot or just because and a Lake Execution by Electrocution can still happen, a Bad use of a Electrical cord can still cook someone or set afire the dock or a boat or plastic/nylon/wooden/cloth materials swimmers are using. Goes that same level of insanity for House or business electrical, saw it at the power station where GFI breakers were considered perfect until they found could fail so went to Ground Fault supply breakers to those panels where they too could fault even failing to remain closed under Normal operations, then they just expand upon expansion trying to stop ALL injuries which is a No Brainer Not gonna happen as some man made component WILL fail, or a human will fail or a human will intentionally bypass. There is only two absolutes, Death and taxes where even in death the dead are taxed. Edited by DMiller - 13 Jan 2020 at 6:39am |
jaybmiller
up here, pull a permit and ALL bedroom receptacles MUST be replaced with new 'arc fault' versions...$$$$$ and of course since that 'office' was or could become a bedroom, those receptacles must be replaced as well.....
trace
no permits here, live in the country and that one of many reasons why.
LOADER |
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
I don't thinks you want my advise on this, if I gives you any, someone will pop up and SLAP me silly! lol
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13353 |
You might outa check with your county inspector bout the " In The Country" requirements,,, That's the way it USED to be out here "in The Country" where I live. You used to not be bound by "City Laws" and most people were moving outside of city limits to escape the rules and regs of city life. Till bout 15 years ago and the county adopted ALL of the City and State regulations,,,,and,,,there went the neighborhood,,,,,,
trace
electrician will know about permits if needed, been in business for a long time in this area. they will do the job to code. don't need the gooberment to tell us that. lol.
LOADER |
Dave H
In the kontry where I live, inspections, lectricians, et all re not required. I would a had those things hooked up and running long long ago. If the code police become active, someone else will have to contend with them. Got a good one for you. i had REA run the drop in when establishing this homestead bout 20 years ago. I asked them about running the juice from their drop to the service panels. The reply I got was once they put the drop with 200 amp breaker they are out of there. Nice huh.
Coke-in-MN
That EMT or Rigid conduct has been used for ground for many years - the part of making sure neutral is bonded to panel and the EMT is all tight at joints is important .
Many things in Electrical Code have changed over the years , from Ground Fault, to Now ARC Fault - But like a friend who had to have a hard wired smoke alarm in system but - the units have a small leakage or draw which will trip a ground fault breaker - some things require a work around . Remember the EMT is a ground - not a Neutral - then a neutral is not always ground either - |
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
I doubt it's code, but you could buy a single wire, preferably in green. Run it along side the existing cable. Zip tie it to the cable and connect it where necessary, at both ends. I had to do this many years ago for a guy that had a kid in the hospital. They wouldn't allow the tv he brought in for his kid with a 2 prong plug. The hospital approved my method.
DMiller
Sorry Coke, the current rules from the Electrical NFPA genieasses is that even with EMT have to present a Solid ground from supply box to device. A Bonded ground is a Clamped Bare copper Neutral Wire run External to the Conduit and fastened at the beginning then end of each run with a threaded fastener or Bonding Clamp.
Coke-in-MN
Will have to dig out my code books , then they are dated since the time I got my Building Inspection Degree . Electrical was a side part of it but required so if you seen something that was not right you could inform the Electrical Inspector , same with Plumbing Inspection - was required to take that class but could not do the inspections .
Odd thing on the plumbing part - the instructor and i had some heated discussions as I had my Pipe Layers certification and my Septic Inspectors License as well as Designers License for septic and he swore that was in plumbing codes but I had to show him his Plumbing License stopped at the point 3" outside of foundation or footing - and my Licenses took over at that point for septic systems . |
festus51
Orange Level Access Joined: 26 Mar 2017 Location: Osage City, KS Points: 1639 |
I do not think a emt is legal as a ground or neutral. The reason is it is too easy break a joint and then no ground or neutral
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Jordan(OH)
Orange Level Joined: 11 Sep 2009 Location: Celina, OH Points: 1545 |
Emt is perfectly fine and code compliant to use as a ground.
jaybmiller
might be 'perfectly fine and code compliant' BUT I've seen MISSING screws where conduit connects to boxes ! hmm, OK, I DIDN'T see the missing screws, rather the screws were MISSING.... There's No way I'd trust that installation for 'ground'. Also conduit does corrode or oxidize or whatever...it 'degrades' over time and those screws should(need) to be snugged up once in awhile. I KNOW that 440' of it is NOT a great ground.Had to string a 'solid #12 green wire' as a ground for one install.
shameless dude
remember to lick your fingers before handling the wires.
Walker
Orange Level Access Joined: 12 Sep 2009 Location: oh Points: 8039 |
I thought it was lick the wires before handling your fingers.
Jomaryngs
Bronze Level Joined: 18 Apr 2022 Location: Luton Points: 2 |
I would not pay attention to the ground wire. Who needs them anyway?
But if you are not an expert, I would suggest you look for a professional to do the job. You can call me, for example, if you live in Oregon. If not, I feel sorry for you indeed – the best state of them all. If you still want to do it yourself you can look for a piece of advice here https://www.electricianclasses.com/careers/. They can tell you how to become a decent electrician so you can solve problems not only in your house but in the houses of the other people too. For money. |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77234 |
spam reported
DMiller
EMT will work for a Ground HOWEVER not legal anymore unless BOND the ground with the Third Wire to all appliances.
Post Reply | |
