Mower Conditioner and Sorghum |
Post Reply |
Author | |||
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11388 |
Posted: 14 Jan 2022 at 9:34am |
Will be buying a new mower for this coming year (I hope). I typically grow 10-15 acres of sorghum sudangrass, which gets VERY tall, especially if I don't get to it right away.
Question is on conditioner type......I've only ever cut it with roller conditioners, both steel and rubber and both seemed to do OK. A lot of the units available have the "impeller" style conditioner, and they're a bit cheaper. Seems it would do OK in regular hay. And that style is all I've ever used. So, hard for me to envision stuff that's 10 feet tall going through those impellers alright? Any experience or thoughts on that? Thanks all.
Sponsored Links | |||
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4635 |
Sounds like you are presently using a haybine? Are you looking to buy a discbine with flail? Uses fingers instead of rollers?
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Think I’d go JD Moco with flails if you are planning to get it dry
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1008 |
I had a jd 925 disc mower with the impeller. Worked great with millet
allisbred
Another option if you only need to do that acreage is one of those MC rotary scythe mowers. Can save a bunch of money but will suck some hp. We still have a 8’ that seems to have the occasional need. Just need to grease the bearings about every few hours.
Edited by allisbred - 14 Jan 2022 at 4:16pm |
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50496 |
I used to cut it with a drum mower, followed by an old NI roller conditioner, 1 steel and 1 rubber roller. Thing is, just because it can grow to 10' tall, doesn't mean that you SHOULD let it get that high! The bigger it gets, the longer it takes to dry out! When I used to cut it, I aimed for 4-5' tall, and even then, sometimes it took a week for it to dry out enough to round bale.
Glenn (NJ)
Bronze Level Joined: 11 Sep 2009 Location: NW NJ Points: 46 |
From a JD Sales manual I found online:
The impeller conditioner works well in legumes, especially alfalfa and most all-grass crops. Impeller conditioners are not recommended for thick-stemmed or cane-type crops over 5-ft tall.
Tbone95
Yes, I currently use a Heston “haybine”. Mine happens to have 2 steel rollers. I intend to buy a disbine, haven’t decided on which one yet. JD is in the running. This summer I borrowed a new holland discbine with 2 rubber rolls. So I’ve never cut the stuff with a flail conditioner.
Dry down is not a concern since I chop it for silage. I try to get it done at 5-6 feet, but that’s not always in the cards, and that’s still hard to imagine going through, even though I’ve never operated one with flails. This year, most of it was 13-14 feet tall and still went through the New Holland just fine. Glen, thank you! Looks like my concern is legitimate. Do lots of hay acreage along with the sorghum. |
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
In this part of WI, lots of dairy farmers grow Sorgum. My neighbor cuts it with a self propelled 14ft New Holland discbine. Has roller conditioners and cuts when between 4ft and 8ft high. Never had a problem going through the rollers.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Tbone95
Thanks. Yeah, I’ve done it no problem with rollers. There was a spot this year that was so thick and tall it had some trouble going under the lean bar and into the machine, but once inside the machine passed it through no problem. |
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
why not just cut the sorghum with a direct cut silage head? that would eliminate a pass with the mo-co. or does it need to 'dry' for a day or so for quality?
Yea, what Glen said about the flail conditioners on big sorghum/cane, I had a neighbor help some time ago with a flail conditioner, it done nothing to help dry-down, didn't break the stalks at all, and threw the windrow down hard on the ground, wasn't "fluffed" at all. took forever to dry to bale...
Edited by Michael V (NM) - 16 Jan 2022 at 11:05am |
Tbone95
Yes, it should wilt down some as it is very wet when first cut. Plus, I have to buy a mower anyway so I might as well get something that will work with everything I’ve got going. I’d have to buy a head and a mower for that way.
Never a perfect plan….and thanks for your input. |
JohnColo
Orange Level Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
I've cut sudex with my Hesston 1345 hydro swing swather with flails, seems to do a pretty good job of cracking the stems. It takes longer to dry then hay but the stems have a lot more water in them. I spread the windrows as wide as the machine allows and then rake it up a few days later. I've owned three JD swathers over the years, finally learned my lesson (must be a slow learner!), Will never own a green haying machine as long as I live!
*DougW
Bronze Level Joined: 11 Jun 2017 Location: Lancaster PA. Points: 75 |
I have 956 moco with impellers. I mow
Sudan for a customer, usually 6 feet high. No problem with impeller plus no worries with stones and rocks or plugging the rolls with a slug. I have been told by customers, grass hay dries faster with a impeller. There may be a little more leaf loss in alfalfa but keep the rpm's set on slow speed, no problem. |
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2855 |
Neighbor has a Deere with impeller and majorly regrets getting talked into the impeller. He thinks it doesn’t dry as well. Buy a 7230 NH and enjoy life.
Tbone95
Gotta love it. Ask a question, never fails, there will be diametrically opposed answers back to back. Thank you everyone.
victoryallis
And that should surprise you how? For example ask on a snowmobile forum what’s the best first sled. Some guys would say Arctic Cat some Polaris, others Ski Doo.
Tbone95
Doesn’t surprise me at all. Hence the laughter and statement that it never fails.
Must use opposite inflection on your side of the state. |
cottonpatch
Silver Level Joined: 17 Nov 2010 Location: VIRGINIA Points: 285 |
Go with rollers. Flail machines pull a lot harder than roller machines. Impeller machines do not crack stems, contrary to input above, they work by removing the waxy cuticle from the stem. Major drying difference in crops that have heavier stems such as sorghum using the rollers which in fact do crack the stem.
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Reply | |
