leaky WD45 engine |
Post Reply |
sploke
Silver Level Joined: 27 Jul 2015 Location: CT Points: 113 |
Posted: 17 Sep 2018 at 7:16am |
I've had an oil leak on my WD45 since I purchased it. It seems to be getting worse so I've decided to finally do something about it. There's a pretty steady drip where the engine meets the torque tube. Initially I assumed it was the oil pan rear arched seal, so I dropped the pan, cleaned everything up, got all new gaskets for the pan and reinstalled. Didn't make a lick of difference, other than now that everything's clean, I can see the drip path a little better. It looks like it's dripping down between the face of the clutch housing and the rear main bearing cap, then onto the oil pan gasket and down from there.
So now I'm thinking it's most likely the rear crank oil seal. I see that you can replace the lower half of the seal without too much effort. I really don't want to get into pulling the engine off to replace the whole crank seal if I don't need to....has anyone had luck fixing this sort of leak by just replacing the lower half of the seal?
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Sounds normal. Not sure about the permanent fix. I did a couple oil pan gasket updates that helped but did not cure it. Probably pulling the engine and crank is the only way to get it done right. The experts will be along shortly.
Regards, Chris
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
don't have to pull crank but if you want to actually fix it,pull engine and rear main cap.Don has a helpful video on here to guide you.It is not a big job to remove engine.May seem like it if you've not done it.
sploke
The complicating issue is that there's a loader mounted on the tractor, so I think I'd have to take off the loader in order to separate everything else enough to get the engine out...maybe? I haven't looked at it that closely, when I started it up and saw that it was still leaking I was so ticked off I just packed up the tools and went in for dinner.
Sugarmaker
Have had many Allis events where I just had to walk away!
"Its only nuts and bolts" (Don (MO))!
Regards, Chris |
Post Reply | |
