increasing blade speed.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 2:10pm
Hahahaha!!!
In all honesty, as I figured.
Glad it worked out for you.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 4:47pm
mtd says lower in front , tall wet heavey moister grass i think higher in the front is a little better espeicaly if the front wheels are laying it over a little
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 4:53pm
2x that on the blades upside down  or the chain saw chain backwards a few of those come threw here each year
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 5:22pm
I had a JD 318 I repowered with a 24 HP Briggs.
JD had a speed up pulley designed for that 52" deck.
I got one but needed a shorter belt.
Said and done when it's wound up it sounds like an airplane.
Made a heck of a difference. Son uses it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 6:50pm
Dixie Chopper I have says blades a little lower on front.  Logic also says that.  If the front is too high, you will have a lot of short cut grass, stuck under the deck.  Note: Deck height in front does not always equate to blade height.  Drive to a level concrete pad, take a wooden block with you, and check the actual blade height vs the deck height.  Properly tuned and adjusted, blades should always be lower in the front.
OH, and synthetic oil is better, tooWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 7:19pm
I never did understand what is best as far as deck adjustment height front to rear. Too many different opinions. Never really gave 2 chits as much as getting it to cut level.
Only matters to me if, when mowing, if it's sticking up, cut it down and it's all green.
I'm the only one that has to look at it. Only others are friends and trespassers.
UPS and the mailman now and again.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 6:37am
Well I looked the book over on our new Conquest the other night. Yep the book says to adjust so the front of the blades higher (1/8" I think) than the rear. That's not how we did them back when I worked at the dealership. Now I got to look for the book on our old 1616. I know that it will say the opposite. Why would they change that? It makes no sense as you are going to use more power with the front adjusted higher.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 6:46am
Maybe for mulching effect? And / or so that there's shorter clippings so they discharge easier? 1/8" wouldn't seem like it would make much difference though. Hmm....
