Unofficial Allis Homepage
Here I thought I knew everything
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Topic: Here I thought I knew everything
    Posted: 23 Oct 2017 at 11:14am
But I didn't know this one.
Just what is PTFE lubricant?
My Front Wheel Free Running Automatic Hublock Brake Band on my brick nose F150 calls fer this stuff. The owners manual calls fer Hublock grease. E1TZ 19590 A an when I typed that number in this PTFE lube showed up.
Great. Sumthin else I have to keep in stock.
I still gots my A/C but it's clear out in the barn now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 11:36am
Polytetrafluoroethylene (PTFE) is a synthetic fluoropolymer of tetrafluoroethylene that has numerous applications. The best known brand name of PTFE-based formulas is Teflon
sigh, I'm getting old...
weiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 6:49pm
I thought I knew everything too,  but the wife tells me different every day.
Real heros wear dogtags, not capes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 2:06am
what you gots in your grease gun? use it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 8:03am
speaking of grease guns...............
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 1:05pm
That  PTFE is some good stuff. I am not that smart about machining and cutting of threads and such,but by happenstances I sprayed PTFE on some 2 inch pipe I was threading and it took about a 1/4 of the effort to run that dye cutting the tread. I was looking in the back of my truck for a longer pipe to snip the handle on the cutter but here was this can of spray lube that said PTFE added. So I have used it on all threading since. I will not say the Liquid Wrench brand with PTFE was the best penetrating of the sprays but sure did make it slippery where it did get.
But they stopped selling that color can of spray and have not come across any other that says it has PTFE in it. So I assume the "Fruits and Nuts" running the country decided it was bad for me. But I had cans stashed everywhere and just found a few new never squirted cans the other day. I have been emptying the ones that run out of pressure to spray into one of the pint cans you pressurize with air to spray to make my supply last longer than just poring it on something.
So do any of you know if it is available else where?  Or other brands that may have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 8:39pm
