Unofficial Allis Homepage
Getting "Parade" Tractors ....
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Getting "Parade" Tractors ....
    Posted: 24 Jul 2021 at 8:35pm
Up to their "real life" operating engine temps while on the parade route ? I'm going to stick my neck out and "assume" that you run them in 3'rd/4'th at mid throttle to labor the engine ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 8:02am
Most likely a proper working thermostat, or shutters adjusted to get to a high enough temperature to properly boil off condensation that happens while sitting around as "trailer queens" do.
If it was fun to pull in LOW gear, I could have a John Deere. If you can't make it GO... make it SHINY
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 9:27am
Don’t need to do anything. Drive it.  Just like on the farm years ago some jobs were lots of throttle all day and some mostly low throttle. On the way home open it up if you want.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 3:23pm
Unless its a diesel thats idling along the parade route just drive it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 8:52pm
I have had several in parades in the last several years, I would say half a mile at most.  But I drive the tractor 45 minutes there and 45 minutes back home where the throttle gets opened up.  Just like Ed says, some jobs around the farm require low idle others require high idle.
In a couple of weeks I will have several tractors on a 40+ mile tractor ride, you gotta exercise them!
'49 G, '54 WD45, '55 CA, '57 WD45, '58 D14, '59 D14, '60 D14 '61 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '85 6080
