Generator for 271 |
Post Reply |
WaltDevore
Bronze Level Joined: 03 Jan 2020 Location: IdahoSprings CO Points: 143 |
Posted: 01 Sep 2021 at 3:36pm |
Looking the motor generator on a 1951 Detroit 271 Allis Chalmers HD5. Thanks!
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77599 |
some good reading and ideas........
WaltDevore
Thanks for the link. Good info!
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41184 |
Works well to replace generator with Delco 10SI alternator .
Using a single wire hookup it is all self contained and no external regulator is needed . |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
WaltDevore
Do you think the double belt pulley would mount to that shaft or does one go with a single belt.? Thank You.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4340 |
The double belt pully on mine fit the Delco alternator that I used. It has been some time since I messed with it, but the mounting was not hard. Mostly getting the tightener to fit.
Coke-in-MN
Pulley interchanges - only thing belt speed with large pulley means you need to rev the engine to get it to excite and charge first time .
I found a 2 belt pulley of a GMC truck alternator double groove that was steel (cast) then put in lathe and machined it to the wider belt size - it was a lot smaller diameter so dont have to do that step of high RPM to get it to charge . |
Post Reply | |
