fuel filters 7040 |
Post Reply |
hybrid
Bronze Level Joined: 17 Oct 2019 Location: north dakota Points: 12 |
Posted: 17 Oct 2019 at 7:20am |
also batteries need replacing would that affect performance for fuel supply
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11380 |
Batteries would have nothing to do with fuel supply......unless, you're having trouble starting, and your batteries are such that you aren't spinning the motor over very fast might seem like a fuel issue.
Joe(TX)
Orange Level Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
The only way it could would be if it has the electric fuel pump. Easy to tell, open the bleed at the filter and turn on the key. Most fuel issues are related to filters, fuel line blockage, injectors or injector pump problems.
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
They used to make 2 different fuel filters for those. One is a 5 micron filter the other is a 10 micron filter. After a while it is harder to push fuel thru the 5 micron filters. They plug easier. I always put 10 micron on in the winter. Fuel flowed thru them a little easier. We rented a 7080 after it had been running a hay grinder for 2 solid weeks. The fuel tanks were full of rotten hay dust, we had to pull the air filter with a crow bar and chain. It had the small fuel cross over hose between the fuel tanks. It was plugged with rotten hay. I'll bet we put 10 filters on it before we got everything cleaned/ blew out. Good luck with yours.
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
Tom, if you rented it, I probably would've taken it back.
Was it running bad when you got it? What led you to discover all that on a rental tractor?
Post Reply | |
