crank pulley repair |
tobiaslong52
Bronze Level Joined: 25 Apr 2011 Location: illinois Points: 1 |
Posted: 25 Apr 2011 at 5:56pm |
grooved crank shaft wd front how do i repair?
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41160 |
Crank shaft or the fron pulley ? if crank look to have it reground undersize if pulley use a speedy sleve to cover worn area.
MACK
Need more info. MACK
MilesGray (CO/KS)
Orange Level Joined: 13 Sep 2009 Location: CO/KS Points: 729 |
Repair shop wanted 600.00 to repair my B crankshaft, I am getting it back today, unrepaired. I figured if I could buy a refurbished one for 300-375, why spend the money to repair the old one. Repair shop said it was at .009 and needed to be buit up.
I'm not trying to highjack the post, I need to know how to repair mine, too.
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5620 |
Leave the pulley alone... pull out the seal, drive in a new one, and drive it in either shallower, or deeper, so the seal doesn't ride in the groove.
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
belzona supermetal 111
lazyk3
Bronze Level Joined: 02 Oct 2017 Location: alpine tx Points: 8 |
I pulley in front on drive shaft and cannot get off
Jim Hancock
Orange Level Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1109 |
Lazy K3,
I'm thinking that there is another set screw under the top one in the same hole. Someone will come along eventually and verify that or not but I'm thinking that I've read that on another thread some time back. HTH.
How blessed we are by HIS GRACE!
lazyk3
ok i'll check I did not think of that although I've already broke pulley think of getting chisel and break rest way off
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5155 |
A 'hijacked' 6 year old post !! Gary |
lazyk3
I don't thimk applies here thet shaft is recessed in
tpulley ,it is a double belted pulley check what another set screw underone I removed
lazyk3
I checked no other set screw and I'm starting to break it off the shaft ,I am totally stumped by this
lazyk3
i have removed set screw and some said it has a second screw. could not find opening to fit allen or any thing else, i beat on it ,broke off parts of pulley tried to drill out set screww cobalt drills don't work. it has about four inch play but will not come of ,about ready to find a tourch
lazyk3
i think your right about second set screw tried drilling it out with cobalt drill and they don't work one hard screw,am at wits in
Gary
Don't use torch. Use a 4 1/2" disc grinder with a thin cutting blade. Grind down 'close' to crankshaft, do same on opposite side, then split apart using a hammer and chisel. Gary |
Orange Level Access Joined: 12 Sep 2009 Points: 19364 |
And what model is he even working on???... is it even an Allis-Chalmers ??
Gary
Very good point Dr. The original Poster from 6 years ago mentioned WD, so I assumed a WD. Gary |
lazyk3
I have tried that bought new chisel and tried sawall all didn't work ,I have bought new set of drills and eezzzout new sawall blade, the grinder was hard to get next to and didn't make much of a dents ,but thanks any I amm back at this morning and have for local advice of someone that works on heavy equipment
