which tool to remove screw holding latch plate |
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1011 |
Posted: 31 Jan 2023 at 2:53pm |
went to replace latch plates on arms of rotobaler. It is held in by a machine screw with a big straight head. I can't find a screw driver big enough. I think my grandfather may have had a socket that fit it ? Took the screw to napa today and they had no clue. Anybody got an idea?
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4521 |
sounds like a draglink socket, check with another local auto parts store, used to be real common
Edited by JoeM(GA) - 31 Jan 2023 at 3:12pm |
Allis Express North Georgia
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3113 |
I made one for a different application from bar stock. Not as handy as a socket but plenty cheap
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50518 |
Take a piece of a big hex key and sharpen it to fit the screw, at you would do with a worn out screwdriver (hollow grind is best). then cut the length you need, and insert the hex screwdriver into a hex socket that it fits into...
MACK
Use a small hammer and punch to drive on end of slot of screw. MACK
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1905 |
I have had good luck with an impact tool. A great opportunity to use a hammer.
http://lonsallischalmers.com
Ken McGregor
Bronze Level Joined: 11 Sep 2009 Location: Strathroy, Ont Points: 142 |
We have always used a hammer and punch to remove/tighten the screw. A nick with a small cold chisel on the screw and the body together will "lock" the screw. They have to be kept tight and can be a real pain if they aren't regards, Ken McGregor
dr p
snap on has a half inch socket drag link style 5/8 part number sw40E that works almost as well as the piece of strap steel I fabricated a tool from. 62.5 plus tax
