Allis 645 payloader |
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8580 |
Posted: 18 Jan 2023 at 6:12am |
Does anyone know where I can get some new flex plates for this machine? I am referring to the ones that go between the flywheel on the engine, and the torque converter on the transmission. There are four of them, three are the same, and the only difference on the fourth one, is that it has weldments on the one side of it with threaded holes for the flywheel bolts to go into. I tried minnpar, and they no longer available through them. Thanks
Darrel Edited by darrel in ND - 18 Jan 2023 at 6:13am |
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3178 |
Check with General Gear. Website is Tractorparts.com.
Edited by truckerfarmer - 18 Jan 2023 at 6:33am |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8144 |
I’m curious. What’s the part numbers
darrel in ND
Part numbers out of the allis parts book are:
Three of 3041454-4 One of 3042762-9 Minnpar part numbers are: AC72041454 FAC 73042762 I guess that numbers are about the same. Thanks Darrel |
darrel in ND
Bump
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41190 |
Some parts might be available through a marine supply - It's where I found parts to rebuild the fwd/rev box on my AC 715 TLB - outfit had new torque converter also in stock for machine .
