Sulfur in well water |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9273 |
Posted: 30 Nov 2021 at 5:13pm |
We recently drilled a new well. Has a surfer smell when water first comes out.
Worse with hot water. Anyone dealt with this? Any advice? Looking at a backwash filter |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77620 |
We use to add a couple cups of CHLORINE BLEACH every 2-3 weeks , when we had a well 30 years ago... Its the Hydrogen Sulfide that smells....... Water heater can also "manufacture" hydrogen sulfide as it heats the water ( if its a hot water problem).
---------------------------------- Chlorine bleach can effectively remove medium to high levels (over 6 mg/l) of hydrogen sulfide. The chlorine in the bleach chemically reacts with (oxi- dizes) the hydrogen sulfide eliminating the "rotten egg" odor. Chlorine bleach also reacts with iron or manganese, and disinfects water supplies. Edited by steve(ill) - 30 Nov 2021 at 5:33pm |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21445 |
friend still has it, after 40 years.... has a chlorinator pump/tank system between pump and house... air bubbler near foot valve in well,supposed to 'break down' the sulphur BEFORE getting into the 'plumbing'. Has plastic foot valve(suphur 'eats' cast iron.....)
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3109 |
The sulfer reacts with the magnesium anode rod in the water heater which is why it is more noticeable in hot water. Replace that with an aluminum one. It does not protect as well as the original but odor should be reduced
Thad in AR.
Can I get one at a plumbing supply? |
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1499 |
I removed the magnesium rod all together, and put a plug fitting in its place. The stink disappeared and it's been this way for 22 years and counting. Same water heater all this time.
If you want the Aluminium for anode protection, YES, they are available about anywhere.
just screws into the 3/4 inch plug...... IF you can get it out ! |
plummerscarin
Be sure to use a 6 point socket. They are in TIGHT!
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4340 |
A neighbor had a artisan well that was very strong sulfur. He ran water over a big screen with little ridges every inch or 2 to disperse it out to let the sulfur out into the air. Others that had to pump it up anyway put it though a sprinkler to land in a open topped tank to air it out.
But your seem like much less sulfur than these where dealing with.
john(MI)
I just take that rod out and put a plug in the hole. I also have a two filter tall filter that just uses the paper filters, and a softner. The softner works on water use rather than time. The softner company tests the water and determines at what amount of use the water needs treated. The only problem with our water now is we occasionally get salty water. We do not have the sulfer smell or iron smell. I keep a gallon jug of our water in the fridge and drink that water most of the time. Occasionally get a salty jug!
Thad in AR.
A friend of mine who is our plumber at work is working on this with us. We’re sending a sample off to be tested. We’ll decide which system to buy after we get results.
I’m leaning towards a backwash filter. He recommends a carbon / charcoal filter in addition. |
Tom6070
Bronze Level Joined: 11 Sep 2009 Location: Kendallville IN Points: 52 |
Get a plastic water heater from Menard's. They cost twice as much or more but they work great. Totally eliminated the sulfur smell in my water. Going on 20 years now.
shameless dude
what does that rod in the water heater protect?
shameless dude
we had wonderful tasting water with no sulfer smell since the time the well was drilled in 1953. had to have a new pump installed as it had quit, well company pulled the pipe up, replaced the pump, then he poured something down the tube. wouldn't tell me what it was, but the water now has the sulfer smell and the great taste is gone. caught the well company owner in town and he said that if it's like that we need to have a new well drilled. BS! come to find out thru the years, that is that company's way of bilking people. telling them they need a new well drilled when they don't need it done. most are city people that move to the country and don't know any better! ours is still working fine, and if we let the water sit a bit before using, the sulfer smell diminishes alot.
dee_veloper
Orange Level Joined: 12 Apr 2021 Location: USA Points: 1168 |
The anode rod is a sacrificial rod that protects against corrosion inside the tank.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
Thad in AR.
Bought an aluminum anode today. Gonna flush and clean the water heater and install this weekend. I’m thinking they got a lot of mud in our house cause they didn’t flush the well.
Doing a water test Monday to see if we need a filter or not. |
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8755 |
The mud may be caused by the well short cycling.
If the foot valve is stuck or worn out, the well will pump until the pressure cut out switch is activated. Once the pressure decreases enough, the pump will start again. If the pump shuts off and then restarts in a short period of time and starts again, this is short cycling. Water is drawn up the pipe and then dumps back down the pipe. Our well did this several years ago. A new foot valve cured the problem. Electric bill dropped, water cleared up and filters now last along time before they need changing. |
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13357 |
Hey Clay,,,what is a "Foot Valve" and where does it go on a well,,? We have never had one on the well next door and I'm fixing to install a new pump as the old pump did not work after having sat for a couple of years.
plummerscarin
New term for me. Check valve?
Thad in AR.
I remember the old shallow well pumps (no n submersible) having a foot valve.
Check valve and foot valve do the same thing... Stop water from running backward out of the pump... keep pump primed.. FOOT valve goes at the BOTTOM of the suction line into the water... Check valves can be somewhere else in the line ( normally on the Discharge)... Both stop water from RETURNING to the well.
Thad is right, its the SHALLOW WELL systems that have a foot valve at the BOTTOM of the suction tube...... Deep wells or submersed pumps normally have a check valve at the top or in the house. Edited by steve(ill) - 04 Dec 2021 at 8:31am |
DonBC
Orange Level Access Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 899 |
I have had experience has been with iron bacteria that can occur in water with a fairly high iron content. My first experience was with a 200', 8" diameter well in a valley deigned to produce 200 gpm. It actually had significant artisian flow. They had to get a professional outfit to come and disinfect that well. If you mixed whiskey with that water an interesting side affect was that the drink turned black.
I would occasionally get the sulfur smell from the well water at my previous home so I got in the habit of dumping a couple of tablespoons of chlorine for my hot tub down the well once a month. I would use the hot tub test kit to test the chlorine levels at the kitchen tap. I also changed the anode in each of our hot water tanks as well.
Thad in AR.
Plumber froiend had me run the water several times to flush everything. I let it run for 4-5 hrs at a time.
We did a water test and it’s safe for drinking but will still leave sediment in the sinks and toilets on occasion. Still stinks when water first turns hot. Plumber came out and installed 2 big filter housings. One has a cheap pleated filter and the next a carbon filter. No more dirty water and no more smell. Supposed to change filters every 3 months. |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29433 |
We have a slight sulphur odor to our water, standard Filtrete inline filter takes care of odor(Carbon Element), softener takes care of hardness and deposits. Good water otherwise.
