Tractor tire swap... |
Author | ||
TomYaz
Orange Level Joined: 14 Sep 2009 Location: PA Points: 10314 |
Posted: 12 Sep 2021 at 4:51pm |
Question...
Would a 16.9x28 on 15" rim fit on a wd-45 , and would a 13.6-28 tire, (rim size???) work on a D17 Series one with a narrow front? Was thinking hmm with the D17 with such small wheels do I have a "low rider"? Need to add bouncing hydraulics on the front... Reason I want to swap is I want to make the D17 foot print as low and small as possible so as to facilitate flail mowing my orchard. |
Sponsored Links | ||
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 825 |
Just took 13.6-26’s off a 17 an hour ago. They were on combine wheels.
TomYaz
Well seems the D17 will take the 13.6's
But will a WD45 handle a 16.9x28 on 15" rim?
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Yes— my father has them on his 45 from a 185. Can not spin all the way in with the on the original tires, will hit fender and the adjuster were switched. I know there was some rigging, just forgot what was done as that was 40 years ago. The last set of 16.9’s he put on may spin in as they are not as wide, will probably never find out though.
TomYaz
Well thats an uh-oh for me given my knack for screwing something up. I wouldnt want them on the wd45 as a permament thing, just want to avoid having to buy a set of rims/tires at this time. Thanks!
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6622 |
The 45 won’t work for mowing?
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7202 |
One thing to keep in mind when buying tractor tires: They don't get cheaper!
TomYaz
Exactly! Had a clusterFK with the WD45 tire that cost me $800 when it was all said and done...(long story)
TomYaz
Engine is worn out and underpowered. Want to put on a 72" flail. Plus no power steering.
Bill_MN
Orange Level Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1463 |
Have 14.9-28 on 13" rims on my WD and that's all the bigger I'd care to go, WD45 has taller fenders though so 16.9 would be equivalent. Can't spin in more than 2/3 of the way.
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2848 |
I have 16.9 28's on my WD45 no problems and I can spin them all the way in, BUT an owner before me and before the bigger welded about a 3/8" spacer on the inside of the fender mounts and mounted the fenders inside the brackets instead of outside. Works well and no one notices.
Allis dave
16.9 pics
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1903 |
I have seen two sets of the fender supports with the spacers welded on them. I suspect these where factory built for some application, but I haven't found out what application.
TomYaz
that dont look to shabby...so my 16.9s on 15" should work...was there any mods done to make it so ? (not talking about those duallys...)...Lonn mentions some fender supports?
Edited by TomYaz - 16 Sep 2021 at 6:52am |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3436 |
Here is a link to a thread about the brackets Lon mentioned; https://www.allischalmers.com/forum/fender-mounting-bracket_topic176488_post1491026.html?KW=#1491026 I put them on that 45 because of the 16.9's. They help but you still can't spin the tires all the way in. No big deal to me, they work great where they are.
IBWD MIke
Here's another link to the 16.9 question;https://www.allischalmers.com/forum/musical-tires_topic176172_post1487375.html?KW=#1487375 AC 720 Man, you asked a question in that thread I didn't get answered. I believe the 6080 is a 1984 model. Dad bought it new when I was a senior in high-school. I'll try to remember to check the serial no. |
TomYaz
Thanks....Having the 16.9s on the WD45 for me would be a temporary affair..I would want to have the smaller tires but would need to hold off as the $ goes to higher priority things. WD45 will be the chore tractor and like the D17 as the sprayer would like it to have a small foot print too..If all goes well will probably sell the 16.9s and rim. |
