Need help identifying AC Dozer |
1badmopar
Bronze Level Joined: 22 Jun 2021 Location: Garland TX Points: 5 |
Posted: 22 Jun 2021 at 11:33pm |
Hello. I am in the process of obtaining an AC dozer from my cousin’s ranch. I’m looking to move it about 50 miles over to my ranch. Its been sitting about 20 years, but was used around the ranch without issue until that time. They bought it at an auction back in the early 80’s from a neighboring ranch. However no one can remember the model number or year of manufacture. Since I am in the process of acquiring it, I have started wondering what model it is. I think it is an HD15 due to the twin air cleaners but that is just a wild guess. Any help would be appreciated!
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29450 |
The model number will be atamped with the s/n on the upper right corner of the rear face of the finals housing. Toward the right track below the fuel tank.
Looks like a HD16 |
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 932 |
Is that a blower in the first photo and if it is I don't think a HD 16.
And it has crank area access covers on the LHS
gemdozer
Orange Level Joined: 17 Sep 2009 Points: 940 |
This dozer is a HD15 with a 671 DETROIT DIESEL
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4340 |
Looks like a Detroit to me and is not a HD 14, so it has to be a HD 15. Unless someone spent a lot of time modifying a HD 16.
Lee Bradley
Bronze Level Joined: 13 Oct 2009 Location: Kingston, WA Points: 115 |
Could be an HD-19.
1badmopar
Browsing through the Internet I had read somewhere that the twin air cleaners were a giveaway for the HD 15. Due to the 671 supercharger on the side of the Detroit. That’s what led me to possibly think it’s a 15, but again I’m not sure.
1badmopar
The next question I would have is does anyone know how to adjust the track tension on this model of dozer?
Is it a grease zert like some of the more modern dozers, or is it a nut and thread? |
Russ P
Bronze Level Joined: 13 Jun 2021 Location: Wi. Points: 6 |
I don't know the answer to your question but I'll give a llittle unsolicited advice.
An old dozer that has been sitting for 20 years will very likely turn into a money pit and time waster. I have been there, and won't go back there.
1badmopar
Russ,
I hear you, and don't disagree. I just hate to see old equipment rot away. I have restored quite a bit of it over the years, but never messed with the AC stuff. I figured I would tinker on it and see what happens. I have some newer equipment for the real work, this would simply be a hobby. The lack of parts availability does worry me a bit though. Once I pin down the model number, I will order a good set of shop manuals and start reading. Will see where it goes.
gemdozer
The serie number should be stamp on rear housing right side
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3732 |
definitely a 15 with 6-71 and those engine side rails are early style, 16 is different. Parts wise, most items, seals and bearings are common. engine parts readily available. Transmissions rarely give trouble, bearings are common, we put 1 in this winter. Salvage yards out there for parts if needed. Worst issues would be with undercarriage and this one doesnt look shot from pictures so with limited use will last a long while. here is my dads 15 in front of my 16.
Edited by CAL(KS) - 24 Jun 2021 at 11:09am |
One late catch, the rails are on backward, Grouser is supposed to be Lead end of shoe not tail, probably trying to wear the 'Back Side' of well worn bushings out.
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10551 |
The chains look good. Could be bad adjusters. Rear sprocket looks OK in the pic best I can tell. I would check the fuel out, make sure pump is free and give it a whirl. Good Luck! Nice looking water behind her!Tracy
Without measuring, the chains can appear good and be trashed. Found that out on my 7G, measured at 110% worn slick but looked OK, Bushings externally were still decent looking too.
Edited by DMiller - 03 Jul 2021 at 8:39am |
