712 H Hydro Not Working |
rhunt12312
Bronze Level Joined: 08 Aug 2018 Location: North Carolina Points: 6 |
Posted: 22 Apr 2021 at 12:33pm |
Trying to keep my Grandfathers 1973 712H alive and kicking.
Recently parked the unit in the garage and went to use again. Engine started perfect but it will not go forward or reverse. I have checked the tranny fluid and it appeared full and a good clean color of red. Thanks in advance
fleeter allis fan
Bronze Level Joined: 05 Apr 2018 Location: Niagara Ont Points: 133 |
My 916H has a latch on the rear end to allow it to disengage the drive so it can be rolled by hand. Not sure if you have the same thing on your 712H. It is on the top left side of the rear end. I think you pull it up to disengage and push it down to engage the drive. (I might have that backwards.) Could be your drive is disengaged. If you can push the tractor and the rear wheels turn fairly easily, you are disengaged.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620 |
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5170 |
Check drive belt for tension and slippage. G |
DaveBsACs
Bronze Level Joined: 21 Jun 2015 Location: Iowa Points: 15 |
that one should have the two little buttons on top of hydro unit that you push down the spring loaded bracket to disengage hydro.
DaveWisc.
Orange Level Joined: 11 Oct 2009 Location: Wisc. Points: 960 |
I have a junk 712 for parts
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11542 |
Yup! If I remember correctly, my 716H had the bracket on top of the rear. Push the handle down to disengage. As Dave mentioned pushing the two buttons in. Steve@B&B
albrown915
Bronze Level Joined: 27 Oct 2017 Location: Indiana Points: 65 |
When you pull it up make sure the pins come up they’re getting sticky after all these years
Steve in NJ
Great point Alvin! I forgot all about that little problem. My 716H, the buttons used to stilck. A little WD40 around the buttons, and working them in and out fixed the ole' button stick problem. Had a 712H that had the same problem. One button would stick...
Steve@B&B
