Wd45 running rough |
Psdiesel350
Bronze Level Joined: 11 Sep 2017 Location: Ohio Points: 15 |
Posted: 01 Aug 2020 at 8:07pm |
things we have replaced /rebuilt:
Rebuilt carb, New points, condensor,cap, rotor, plug wires, plugs, set the valves, and sprayed ether around manifolds. Only thing I haven't done was to check compression or actually time it with a timing light. I did hook up a timing light to the plug wires and it was randomly cutting out. I dont know where to go from there. Thanks |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7202 |
Set your timing with a timing light FIRST.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Check for slop in the distributor shaft.
1957 WD45 dad's first AC
Psdiesel350
I took distributer off tonight and tore it apart it seems nice with not much slop. I haven't checked shaft from governor yet.
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 608 |
Is this a 12V or 6V system? When you try to choke does it run better or worse?
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1008 |
I don't see replace coil. I'd try that
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
Where did you get the new condenser? About 90% of them are junk right out of the box.
I won't waste my time putting an off the shelf condenser in anymore. Go to NAPA and ask for Blue Streak ignition parts, or switch to a Pertronix electronic ignition. |
Psdiesel350
Yep replaced coil. Actually put a 2nd set of points and condensor on with no change. If ya choke it get worse. If ya pull plugs out they are not wet, just black and sooty.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
These are hard because were not there but even on our own tractors trouble shooting problems may not be easy.
I have this gut feel that you may have a carb/ fuel problem/ Just a hunch. Do you have another good running carb to change? The black plugs may be a indication of fuel issues? Regards, Chris
Psdiesel350
I have a wd. Would that carb run ok on a 45 just for a test?
Boss Man
Does it have an inline resistor? Customer had an Farmall H that was running rough and came down to that resistor being bad.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2197 |
wd carb will run on 45--I have 2 runnin that way
