Fence row D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Topic: Fence row D14
    Posted: 05 Jan 2020 at 5:41pm
Folks,
 My friend Matt pulled this tractor from a fence row a couple months ago. Its rough, but functions. He belted it up and buzzed some wood with it yesterday. Today was a conversion to 12 volt alternator and coil, and battery. Also he worked on the 3 point hitch system. He got the arms with the pivots from another of his tractors (English Massey).
Some pictures:
Serial number- D14 5868
Matt installed the tool box that was on one of My Uncles tractors:
Both rear fenders are rough with crinkles and the left one was welded where it had rusted out at the bottom. Seat is in pretty bad shape but like the fenders still hanging in there!
Where are the brakes on these? Inside the trumpets? Still has some brake left.
This rim is not good but has had some repairs around the valve stem. Power director has good snap. No guard on the PD lever indicating a early model too
Will WD rims fit on a D14?
Added a angle and pins for the three point:
Top link bracket assembly fabricated:
Edited by Sugarmaker - 05 Jan 2020 at 5:47pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:46pm
Yes,  The WD Wheels will fit on the D14.  Any 8 bolt rim should fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:52pm
Re the brakes, they are inside the axle housing, real close to the diff.  You have to pull the FD housing, then the axle housing, to get to the brake drums and shoes...HTHWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:52pm
Thanks John!
 I am working on him to do some horse trading! Maybe bring it to my house and leave it for a while. I mean he does have my TD6 dozer at his place!:) Seems only fair and he is a IH guy!
I am going to have a real nice set of Firestone 13.6-28's from the WZ, that would bolt right on this D14!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:55pm
Dave,
 Thanks! So are they of similar difficulty to change? Compared to a WD series tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:59pm
looks like nice rubber ! so find some combine rims ! I KNOW they fit  !!
Yes, brakes are 'inside'..if you want practice...hint,hint....
There's an axle seal that goes,allows diff oil to 'lubricate' the shoes. Also the ram cylinder seals can go or the hyd hose inside the diff. The telltale is having to add hyd oil.... If you open it up for that, have a hyd shop make the hose WITH 1 swivel fitting, it'll make reassembly go easier as the AGCO part(still on my shelf) doesn't swivel...
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 6:11pm
Dave,
No, they are far easier to change. You need a hoist to hold the axle housing, with or without the tire attached, when you slide the axle housing out of the trans/differential housing. 4 bolts hold the axle to the transmission. No rusted brake pins to mess with. The brake drum will stay with the axle in the axle housing. The 2 brake shoes will be attached to a plate that stays on the trans housing similar to the drum brakes on 80's/90's trucks. Once you have the axle off it will be practically self explanatory. Be sure to change the axle shaft seal when you have the axle out.
www.awtractor.com
A&W TRACTOR 920-598-1287
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 6:35pm
The 28" wheels was a factory option.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 6:43pm
Late model D14s do not have the guard on the hand clutch button either.  Nice straight tractor there.  She should clean up nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 7:32pm
Folks,
 Matt needed some chains and some help today with his D14. I supplied him with some very worn tire chains that had been used for many years on WD's.
When we started looking the spin out rims were not out away from the fenders far enough so we spent a hour or more getting the three eccentrics per wheel loosened and he made some plates for wheel stops.
Stop for wheels, add ed both sides on the rail. plate with bolts through them. Looked like this farmer fix was going to work ok.
Installed the chains then cut some off each to fit the tire.
Some bungees and it was ready to plow snow. He said it worked much better with the chains!
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 8:39pm
Nice Tractor. Looks like something I would drag home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 8:41pm
Is that the type of chains that will tear chunks of the cleats off of the tires?  Or does that only happen if they are loose?
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 9:09pm
Nice, Chris. It's always fun to watch you reclaiming another old AC!
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 10:32am
John, Guys,
Yea this is rough around all the edges, smokes some on start up. But it still moves and functions.
I have run these old chains some and they didnt seem to bother the tires. They are so worn and smooth or maybe sharp in some areas. He was happy to get them, We spent some quality time getting those rims moved and the chains on. All in all a good couple hours.  I beat on the heads of the eccentrics with a 10 lb sledge several dozen times which may have helped too? I was very surprised that we got the eccentrics to turn. It cost a cheap socket and a 1/2 inch ratchet before they all moved. I told Matt he was pretty lucky as these typically have to be removed from the tractor. He should buy Loto tickets!
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 11:50am
Gotta wonder if a 3/4" socket fit the eccentrics ? My D 15 seems to be 25/32 . Never did find out for sure . Thanks
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:19am
On those eccentrics; I have a (I think) 20mm 1/2" drive socket welded to a 3/4" adapter. Works good on those extra tough ones!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:55am
My CA has 1/2" square eccentrics. I welded two 1" six point 1/2" drive sockets together with the square 1/2" drive openings facing out...one end for a breaker bar, the other for the eccentric.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 10:47am
If memory serves , I think it was 21mm and 25/32 I was looking for . Was hoping to buy one locally and if it didn't fit return it . Of course I can get them online . No big deal , I just wanted to remove them for some paint . Thanks
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 11:20am
20mm is .78739 in   21mm is .82676 in    3/4in is .75000 in    25/32in is .78125 in
HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 11:50am
Well heck ! Maybe it was 20mm I was looking for . Thanks Elliott
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 7:14pm
I use a 20mm impact socket to turn the eccentrics
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 8:21am
Rails do not look like the eccentrics were run loose as the rails will show "flattening" of the metal. Have removed eccentrics that were worn paper thin and one old D15 I picked up had rails worn beyond use on both rims as ran far too long allowed to move.
A clunking sound is usually a dead giveaway on worn eccentric inserts but finals low on fluid will cause the same clunking sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 8:32am
Great! Another fence row save! Way to go Chris n' Matt!!
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 8:02pm
Almost hard to believe this is a "fence row find". Thanks so much for saving her, we need all the A-C's we can get since they stopped making them. Keeping her running is the best thing to do. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 2:36pm
Guys,
I am a little worried about Matt! He is 20 and already has 23 tractors! At this pace he will need more storage soon!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 4:37pm
Maybe wife would say 11 1/2 tractors. Wink
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 9:10pm
Matt... Nice find! I just found a stuck in the woods D17 Series IV. That puts my total at sixteen tractors, not counting the off color ones. Don't let anyone tell you twenty is too many. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 5:45am
Guys,
 I will let him know that you approve of his tractor hoarding!
I think with less young guys that are interested in tractors, they will have to step up like Matt and just have way more than normal. Wait, whats normal?:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 5:18pm
Folks,
 Matt came over today with the D14 to borrow my buzz rig to cut slabs. Well it did not go as planned!
When we had the top link in place the buzz rig tipped way back.
We had to use a short chain to get the buzz rig high enough that he could load it.
Luckily he has another 20 tractors to choose from so he mounted it on a 9N and it worked fine. PTO was too short too?  Not sure what is going on with the geometry of the new 3 point we put on the D14??
Edited by Sugarmaker - 31 Jan 2020 at 5:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 7:27pm
Looks like the 3 point is a hangin pretty far back, there...Wink
