WD wiring |
Post Reply | Page 12> |
Slowmotion
Bronze Level Joined: 24 Mar 2019 Location: SW MO Points: 48 |
Posted: 24 Mar 2019 at 1:19pm |
I recently bought a WD that was about to be parted out. The fellow who owned it had bought it at an estate auction. I thought it looked too good to be parted out. It has no battery box or battery, and the generator looks as though it has not been wired into the electrical system for many years. My guess is that a battery was used to start it, and the battery was recharged between uses with house power and a battery charger. I know little about such things, and I’m wondering if that would make sense, and if putting a battery box and battery back in the system would be a reasonable approach to trying to get it running again.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3112 |
Your theory may be correct. That was the was how our Super M was before we inherited it. Generator was bad. After FIL died we just charged it overnight to use all day for cleanup. Just didn't use starter. Now that it's ours I converted to one wire alternator
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 934 |
I would do something temporary to hold a battery and try to get it running before buying a lot of parts. Distributor or magneto? Any idea if it was last run as 6 or 12 volt? If a distributor and there is a ballast resistor in the wiring ahead of the coil, they were likely running a 12 volt battery.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
If you have a magneto ignition, a good battery will start the tractor many times without recharging, IF it's tuned up properly. I know a guy that has been using a 12 volt battery for years that way. He might put the charger on it once a month, just so he knows it's good to go the next time he needs it.
I would find out how good the engine runs, before putting time and money into a charging system. |
Walter(MO)
Bronze Level Joined: 26 Dec 2009 Location: Warrenton, MO Points: 127 |
Figure out a way to hold a battery temporarily. You can hook up a battery and find out if motor is free or use a crank to check motor. If engine turns with a battery try to start the tractor with fresh gas and check for spark. No need to spend money on things like battery box and generator until you know what you are dealing with. Simple things first.
Slowmotion
It will turn with a crank. There is a heavy rubber strap near the battery platform that looks like it was probably used to hold a battery in place.
I would like to know if there are any major problems before I sink a lot of money into it. I need to figure out for certain if it’s 6 v or 12 before I buy a battery. I can’t lift car batteries anymore, so I’m going to put a battery box on it and get help putting a battery in it. If it’s worth a rebuilt generator, I wonder if it would be worth converting it to an alternator? If I get that far, it seems like this would be the time to do it. |
Slowmotion
The spark plug wires come out of a bare metal attachment that has Fairbanks Morse Type FM on its side. It’s bolted onto a large metal thing that’s the same color paint as the rest of the tractor and appears to be original equipment. It has the firing order on it. At the front end of this is another bare metal piece bolted on that appears to be part of whatever the back end piece is. I see no coil or ballast or anything else.
Jim.ME
You said the generator is unhooked, so you don't need to be concerned with it for now. If it has a magneto ignition system you can use either 6 or 12 volt battery to try starting it. If it has a distributor with a ballast resistor in the wire going to the coil it should be ok to use a 12 volt battery. If no resistor the battery needs to match the coil. With no battery hooked up take an ohm reading between the two primary wire terminals on the coil and post the reading. Battery voltage the coil is for can be determined from that. Polarity of the battery should also match coil polarity. Post a few photos someone may see something that might help. Good luck, hope things come together for you and it starts easily.
Jim.ME
You have a magneto ignition.
Slowmotion
So if I have a magneto ignition and there is no coil, do I use a 6 volt or a 12 volt battery to start it. I used to have an F-20 that I cranked with no problems, but I'm leery of cranking now.
CTuckerNWIL
It won't care if you use 6 volt or 12. Just don't crank it for long periods of time.
The Magneto has a coil, inside, but doesn't need outside voltage. The mag makes it's own spark. If there is a wire hooked to that little stud with the metal tab, remove it. It's a ground wire that shorts out the spark of the mag and if any part of the wiring or switch is grounded, it won't have any spark. You push that tab in to shut the engine down. Edited by CTuckerNWIL - 26 Mar 2019 at 9:46am |
Slowmotion
Looks like I pretty much have the info I need to move forward. Thanks everyone. I'm keeping my fingers crossed.
Krazy Karl
Silver Level Joined: 12 Sep 2011 Location: SE MN Points: 203 |
Previous ower probably cranked it over by hand. And didn't use battery. Believe in operator manual states if not using battery to unhook generator.
CTuckerNWIL
With a magneto ignition, there is no need to buy a battery until you figure out if it's worth investing $ into. You can jump the starter with any 12 volt car or truck , just make sure you don't have any connections from the battery to any of the old wiring.
Find out if it's gonna run, then worry about a charging system and battery. |
Slowmotion
Where would the starter switch mount on this tractor? The control panel box is hanging by a wire, but there's nothing in it. I see a started switch advertised that seems to be contained in a box that is the same size and shape as that box.
Slowmotion
After doing a lot of digging, the light finally went on and I found where the switch is supposed to be, and it's there. And the long rod that's used to engage it is also there and attached. It looks like all I'd have to do is attach a battery. But I'll drain the fuel tank first and I'm thinking about changing the oil. It doesn't appear from what I've read and can see on the tractor that there is a fuel filter, other than the settling bowl. But maybe I should wait on changing the oil until I find out if it will start. The odds are probably 100 to 1 that it will need a new starter and switch. I bought a new battery box, and I'm wondering if there are batteries with terminals in the right place for the box?
CTuckerNWIL
If you follow original directions, "Buy Clean fuel, Keep it clean" there is no need for a fuel filter. That's what the sediment bowl is there for. It separates water and sedimenet from the fuel as it is used, and should be cleaned regularly.
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
Re: proper sized battery - yes. Take measurements of your battery box. You want a battery with top-mounted terminals. Take your tape measure to your local battery store of choice and start measuring. Make sure that the box lid will clear the terminals with room to spare.
WC, CA, D14, WD45
CTuckerNWIL
Then add a piece of 1/4 inch plywood or hardboard flooring over the battery, before you put the top on. |
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24021 |
there was a lot of tractors of all flavors sold without a gen, or battery, or starter, w/magneto during the war
I am still confident of this;
Slowmotion
The 26R group looks like it's about the right size, but the terminals are opposite each other, and the openings in my battery box are staggered.
Jim.ME
Offhand I can't think of a 12 volt having staggered (diagonally opposite) posts like the 6 volt group 1 batteries. You will need to change or rework the cables to fit the battery you get. As it appears you are converting to 12 volts you will be best to configure it as negative ground.
Slowmotion
There's not much to convert. The lights and generator aren't wired up, and it runs off a magneto. I don't know if the starter is any good, but I seriously doubt it, and if it is, I've read that it should work with a 12v battery. Maybe the simplest thing is to cut another opening in the box. 12v is more readily available and probably cheaper.
chaskaduo
Maybe a longer cable would work before cutting the box.
Orange Level Access Joined: 12 Sep 2009 Points: 19498 |
Look at a grp 26, I think it's bass-ackwards of the 26-R.
Jim.ME
A new cable with few more inches of cable should be able to use the existing openings in the battery box, even if the terminals are both on one side of the battery, not staggered.
A 26 has + on the left if looking down on the battery while standing on the same side as the posts. As DrAllis said, a 26R is the opposite, the + is on the right. |
Slowmotion
It looks like the cell covers would get in the way of one of the cables with either the 26 or the 26R, especially if I put an insulator between the posts and the lid.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Before you start it the first time get a clean drain pan and remove the oil pan drain bolt for just a second to make sure you don't have a gallon of water in the bottom of the pan. If just oil comes out you can put it back in and go from there.🙂
1957 WD45 dad's first AC
Slowmotion
Sounds Like a good idea. Thanks.
Slowmotion
I got the battery wired in and tried the starter today. There was a little arc at about where the start lever connects to the solenoid, and then nothing. I put a charger on the battery and it didn't register, just hummed. I'm thinking a dead short in the solenoid or the starter, but I know little about this stuff.
