7020 Engine Noise |
Blustery Knoll Farm
Bronze Level Joined: 04 Dec 2017 Location: Northern IL Points: 117 |
Posted: 17 May 2018 at 11:19pm |
Well, I have another 7020 problem. Pulling the field cultivator today, I noticed a bit of hot oil smell, then saw that the temperature gauge was running almost 210. Usually it's quite a bit lower than that under load. I stopped and idled to let it cool off a bit. After it cooled to where it normally would run, I started driving again and geared down to the next lower speed and it still wanted to heat up again. Then it developed a knocking sound. So, did I spin a rod bearing or something nasty like that?
It has been loosing coolant very slowly since I bought it. I kept finding little leaks from loose clamps and fittings, so I figured that was where it was going, but it's still happening, even though I think I finally fixed the last of those. There wasn't any coolant in the oil when I changed it last month though. So, what's the next step to diagnose this without sending a rod through the block? Drop the pan and start pulling rod caps? |
MACK
I would say antifreeze going past sleeves oring onto piston skirt scored a piston. MACK
Blustery Knoll Farm
Well, the motor is going to have to come out to change the torque limiter anyhow, so I guess I will just start taking things apart then.
Another detail. It was intermittently making a really nasty screeching sound, kind of like a dry alternator bearing, but I checked and it and the water pump spun fine. |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Sounds like a large project. Hope you have back up equipment during the down time!
I like your farm name!
Regards, Chris |
Blustery Knoll Farm
Yeah, I do have backup equipment, and I am done with most of the spring tillage. So, I just have to use the smaller tractors and tillage equipment for the rest of the spring.
GM Guy
Orange Level Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1973 |
The screech sounds like chunks of rings trying to exit.
Wasnt this the tractor that ran really hot (fueling issues) when you first got it? I would say it is damage from that finally showing its face. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
