shifter fork
prospolaris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prospolaris Quote  Post ReplyReply Direct Link To This Post Topic: shifter fork
    Posted: 28 Nov 2011 at 7:31pm
so i took the top of the trans on the 190xt today just to see what was going on ion there. the tractor pops outa 3rd gear as i know they all seem to. ass i look at the shifter forks the 3rd gear fork is worn down to a 16th of an inch they are very thin. i know people say weld them up but steiners has them for sale for like $75 as i take it apart the 1 spring with the ball bearing, the spring is broken. would these 2 thing have anything to do with popin outa gear?
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 7:48pm
Very much.
I would be glad to find out it's there and not the gears.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 9:28pm
Shift fork could only be part of the problem.  Weak bearings on the input shaft can make the shaft move around - this chews up the gears and causes gear jumping.  Just fixed mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 10:06pm
Which spring?? the front one or the rear one??? the front is for neutral only.
This page was generated in 0.373 seconds.
